  New Posts New Posts RSS Feed - 4 Way Stereo Using Two Crossovers??
leoandsmokey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leoandsmokey Quote  Post ReplyReply Direct Link To This Post Topic: 4 Way Stereo Using Two Crossovers??
    Posted: 27 June 2018 at 1:47am
Hi All,
I'd like to achieve 4 way stereo using two active crossovers, if it is possible.  I have run four way mono using my DBX 234 but I much prefer the sound in stereo.
I'd like to keep my set up as analogue as possible, hence why I'd prefer not to use a speaker management unit like DBX Driverack or Berry Ultradrive.
I have also considered using a passive crossover between my mids and tops, but I would like to be able to have some control over the crossover frequency here rather than having it at a fixed point.
So my question is - In 3 way stereo mode on my DBX 234 can i send the high channel output to another crossover as input and then split the signal again from there?  See below diagram.
Crossover points would be Low - Low Mid 100Hz, Low Mid to Mid High around 800hz-1000hz, Mid High to High around 2.5kz to 3.5kz.
Thanks all..
Do not regret my fate; if I have consented to survive, it is to serve your glory!
James Tengo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Tengo Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2018 at 1:51am
Two 234's, one for left one for right. Keep it simple!
Post Options Post Options   Thanks (0) Thanks(0)   Quote leoandsmokey Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2018 at 2:11am
Thanks James - that hadn't even crossed my mind.  Certainly a lot simpler than what i proposed.
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2018 at 7:48am
And a bunch of link cables for amps so you can do mono if one xover ever dies
BASSHORSE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BASSHORSE Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2018 at 9:24am
or get a bss fds 318 no need for 2 then Thumbs Up
bitSmasher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitSmasher Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2018 at 9:45am
Stereo is just two mono side by sideWink
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2018 at 7:46pm
you won't be able to tell whether the low and low mid are stereo or not. run them mono on two channels and then mid and high in stereo on the other four channels.
