48M Series Amplifiers |
Father-Francis ![]() Old Croc ![]() ![]() Joined: 24 October 2007 Location: Kenya ,Denmark Status: Offline Points: 2700 |
![]() ![]() ![]() ![]() ![]() Posted: 04 May 2022 at 7:57am |
Anyone using dem, think an amp per stark max two per stark , there’s these two amps , https://linea-research.co.uk/48m-series/ , https://www.powersoft.com/en/products/touring-amps/x-series/x8 , looking to upgrade amp racks , hope it all makes sense,
Put it this way running 4mid/tops, 4*215 kicks from one amp and subs from a two or four ch amps , I can’t remember if Dave has 8ch amps (FFA ) subs are B&C 152’s , 8ohm and it’s 8 subs CSG, toastyghost your advice could be used here , 4xshevo6, 4xMartin 215mk3 , all bassbins in the corner 8xskram Powersoft setup X8 for tops and kicks and X4L for subs , Linea-Research 48m for tops and kicks which of linea’s amp would you drop in for the rack for subs ?
smitske96 ![]() Young Croc ![]() Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 867 |
If going fot 2x X8 you can use one per side. By doing so, you can spread the loads and gain some extra headroom becuase of Powersoft power-sharing.
csg ![]() Old Croc ![]() Joined: 17 September 2007 Location: bedford Status: Offline Points: 5910 |
At this end of the market either Linear or Powersoft are going to provide a very good solution. It’s likely to come down to other considerations other than just sound quality:
Power density- X8 / X4L would win here i think Power supplies- X series can run single or multi phase, on the continent smaller 3PNE supplies are relatively common and make power distro light and efficient DSP- either platform is excellent, personal preference here AES/Dante etc- are these formats required Cross-hire potential, what is in other companies racks? Price point- what are you paying for what? Etc etc |
re-production ![]() Registered User ![]() ![]() Joined: 16 February 2017 Location: Suffolk UK Status: Offline Points: 173 |
If your spending this kind of money you need to try both amps side by side. If you need I can sort a Linea demo for you.
For this set up I’d recommend a 44M20 for the subs and 48m for the kicks and tops. The extra current per channel on the 44M20 makes it better for sub.
Thanks for that boss , somethings man need to ask and make sure we are not throwing too much into a basket without asking , nuff companies here but not all amps are here for testing . will PM you soon boss , Is Kyle not using linea-research , just wondering what he's running Danley's with
Kyle is using all powersoft if i am correct.
Smitske Thanks , I wasn't sure about that , I know chris' has powersoft ,thought Kyle had Linea, maybe I'l just have to take a trip over there ,it's been long since i was there .
toastyghost ![]() The 10,000 Points Club ![]() ![]() Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10669 |
Yup. Still waiting for Linea to release software which takes less than 4 minutes to load a group. Six years and counting. |
I kind of remember you’ve something like that before, so I see we are staying with Powersoft, you running X4L , how many B&C 152’s would you run safe off them if power is no problem?
