Forum Home Forum Home > Buying and Selling > Wanted
  New Posts New Posts RSS Feed - 4x 18" drivers for a pair of 218
teeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Topic: 4x 18" drivers for a pair of 218
    Posted: 10 May 2022 at 5:48pm
Hi guys, I'm after 4x drivers for a pair of 218's that I'm getting shortly.
Open to any suggestions of something suitable!
Thank you.
monkeypuzzle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote monkeypuzzle Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2022 at 6:32pm
I don't have any 18" drivers but anyone who does may need a bit more info.  Is the box reflex? - what volume/tuning, is it horn loaded? - what type/plan? What amp would you be driving them with? - (power available/required). Then you might get some offers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2022 at 9:43am
cheers monkeypuzzle, gaps in my knowledge showing here...
i believe the cab is modelled on the martin 218, it certainly looks like it. from what i know it's a fairly common design with loads of similar things out there, i thought 218 was a common name for that reflex design so thought it would be enough info!
i think martin use b&c 18tbx100 in their 218s so something like that maybe
i have 4 x 1220W @ 8 ohm power wise. the amp is a 4ch, but can only do 8ohm bridged to 2 annoyingly.
luton_soundman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote luton_soundman Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2022 at 1:22pm
Hello i have x4 original Turbomax 1200i on the fane chassis for £800
This page was generated in 0.157 seconds.
