4x18" subwoofer (Industrial Bass Machine) |
Post Reply | Page 123> |
Mircea Bartic
Old Croc Joined: 18 February 2005 Location: Romania Status: Offline Points: 2582 |
Posted: 06 July 2018 at 7:54pm |
So, I finally lost my mind and decided it's time to build the project that was lurking in the deep crevasses of my mind for several years now.
Something too big, too heavy and too useless for most applications. I give you my latest experiment: the 4x18" Subwoofer conveniently called IBM , which is an abbreviation from "Industrial Bass Machine" Why build it then? Because I can! and ... I don't care if someone will ever buy such a product. It's a push pull design built around the Celestion CF1840 subwoofer driver. (700W Cast frame with ferrite magnet and 3" voice coil) each sub uses 4 speakers inside a manifold the outer dimensions are 1450mm W x 552mm H x 1100mm D (without wheels) Prototype is being built right now from chipboard to keep costs down in case it is a huge failure. in the images below the braces are not mounted and the central manifold is not screwed in yet, just placed inside the enclosure to see how well it fits. the central manifold: Edited by Mircea Bartic - 06 July 2018 at 7:55pm |
Contour
Young Croc Joined: 03 March 2004 Status: Offline Points: 623 |
compression ratio for middle two woofers seems too high!
Mircea Bartic
It's pretty high, but the woofers I use have pretty thick cones so they should survive. Also I'm not aiming for very low extension.
I am trying to get some mechanical distortion from this.(the slot gives uneven loading between the inner and outer speakers so there will be more distortion because of the difference in movement) I find push pull subs too clean sounding... The brain loves some distortion in the low end and the perceived SPL will be much higher than with a regular clean push pull design.
I will highpass at 40Hz so the air moved trough that slot won't be so much... Edited by Mircea Bartic - 06 July 2018 at 8:58pm |
djeddie
Lots of people would just do WinISD and HornResp screenshots! I lookk forward to finding out if that compression ratio is too high.
Meat
Old Croc Joined: 05 June 2009 Location: Manc Status: Offline Points: 1514 |
Cool project. The 'designing in some distortion' to give the sound you want is like designing from the point of view of of luthier or musician rather than an engineer. I hope it brings the smiles. Props for showing the build.
nickyburnell
Uber cool. If I may ask what is the reason for the driver choice?
gen0me
Because it is similar to bandpass. Although this driver seems very fast in that box. How does the kick sound? Where did you get those grills?
Mircea Bartic
grill is made on puncing press and powder coated.
It is still a work in progress. The woofers are on the shelf at the moment. I will do some more work on this project today .
gen0me
So you design the press shape and send it to producers? Or you cnc it than press? Or how does it work? Was it economical for a one project?
Mircea Bartic
it is not exageratelly expensive
Actually that particular sheet was designed for another product of ours. I have access to everything I need in my city. Laser cutting waterjet , punchpress and cnc. |
Contour
what is the compression ratio for the woofers firing in that small middle chamber?
Mircea Bartic
about 3.5/1
