  New Posts New Posts RSS Feed - 4x18" subwoofer (Industrial Bass Machine)
BP1Fanatic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BP1Fanatic Quote  Post ReplyReply Direct Link To This Post Posted: 09 July 2018 at 9:54pm
Awesome build!
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2018 at 7:47pm
Just managed to do more work on this project before the bad weather comes in
More pictures
On Monday I will test 2 of the beastsStar
Ex Nexus_3
Contour View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Contour Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2018 at 12:23pm
looks very impressive!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 26 September 2018 at 4:19pm
one sub loaded. The other one will be loaded tomorrow.
I did a quick test with a PKN XE5002 and the output was pretty intense. Can't wait to test outside with some mid tops.
sorry for the shit quality pictures. Some better ones will be uploaded in a few days as I need some help getting them outside.
The good news is that I could lift the loaded sub with just 2 people, which means It's only about 100-120Kg
loading is a bit tricky if you don't know how things are supposed to slide in. The clearance is about 4mm. The drivers need to go in, in a specific order.
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote BP1Fanatic Quote  Post ReplyReply Direct Link To This Post Posted: 26 September 2018 at 4:49pm
That enclosure looks impressive! Any measurments?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 26 September 2018 at 5:41pm
I will do outdoor measurements once I break in the woofers. They are pretty stiff because they are brand new.
Ex Nexus_3
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 26 September 2018 at 10:15pm
Well you have built a tank I give you that, although tbh for the weight to output ratio it's probably not that bad.
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2018 at 6:24pm
Originally posted by BP1Fanatic BP1Fanatic wrote:
.......Any measurments?
 Loud and f'kin louder probably!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2018 at 6:44pm
I have a measurement done but take it with a pinch of salt as I had some buildings around. For example the drop at 90Hz is caused by the building on the right. I will redo the measurement in a free field over the next days.
The sensation is of wobbly eyeballs when the bass hits you. The subs are super fast. Could be ideal for disco music and techno.
They are very very violent. they have excellent kick too. I think I am pleased with the outcome. in the next days I will run some sine sweeps trough them to loosen the suspensions before doing some real measurements and develop a preset for the DSP.
I wasn't after extreme extension. I wanted a one box solution for Bass. (40-100Hz)
Edited by Mircea Bartic - 27 September 2018 at 6:46pm
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2018 at 6:54pm
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2018 at 8:29pm
Looks like it has a nice 'disco thump'. Indeed could make some house and techno heads happy.
Ionkontrol View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ionkontrol Quote  Post ReplyReply Direct Link To This Post Posted: 28 September 2018 at 6:56pm
Would love to hear a stack of these.
Smile
Edited by Ionkontrol - 28 September 2018 at 6:56pm
