  New Posts New Posts RSS Feed - 6-16 ohm amp to 4 ohm speakers cabinet?
Shipibo303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shipibo303 Quote  Post ReplyReply Direct Link To This Post Topic: 6-16 ohm amp to 4 ohm speakers cabinet?
    Posted: 14 September 2018 at 10:23am
Hello guys, I'm a newbie and I don't understand the speaker impedance rules well. I wanted to ask you: My amp output impedance is 6-16 ohm and I want to feed it to speaker cabinet that consists of two 4-ohm mid speakers and one 8 ohm tweeter. Is it possible to do it without damaging the amp or speakers? And if it is, what is the best way to wire them?
(The amp has 5 channels and 100W per channel)
Thanks for your help!
Chris Grimshaw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Grimshaw Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2018 at 12:34pm
Mids in series to one channel, tweeter on another.
Make sure you've got a crossover in place, or the tweeter will not last long.
Chris
Quality sound from Sheffield
www.grimshawaudio.com
taurusty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote taurusty Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2018 at 2:43pm
Make and model of amp?
Conanski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Conanski Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2018 at 8:03pm
Sounds like a home theater amp.
If the 4ohm mids are wired in series and there is a passive crossover between those and the tweeter then the box has an 8ohm impedance overall and is safe to connect to your amp.. 1 box per channel.
This page was generated in 0.059 seconds.
