  New Posts New Posts RSS Feed - 6th order BP kick section
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2011 at 9:36pm
I have had some problems in the past with Doppler effect in a design similar to this
I don't say you shouldn't try, just make sure the speed of air in the ports is as low as possible so there won't be a lot of air moving along with the mid and HF, atrough I am still not shure that this is the corect way to cure the problem after some recent tests.
This can also be observed when running stupid amounths of sub right next to midtops
above a certan limit everything starts to sound muddy when you unmute the sub section.
Edited by Mircea Bartic - 11 January 2011 at 9:40pm
Ex Nexus_3
PolymorphicMark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PolymorphicMark Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2011 at 10:58am
Originally posted by JD01 JD01 wrote:
I heard lots of BP6, but I never liked any of them above ~80Hz. All kick BP6 have failed to impress me, I wouldn't consider using such a design for kick. This is not a matter of taste, but a matter of how true one wants to stay to the original signal.
JD01, when you say how close to the original signal do you want to stay, what do you mean? Are you saying that because the sound is coming form a port the phase shift/group delay effects the kick bass. If this is so, then on a standard bass reflex box with say two 12's a large proportion of the sound will still be coming from the port, so there will still e similar phase shift I Think.
I have a 6BP with a group delay of <7ms form about 80Hz - 130
Free to do what i WANT
JD01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD01 Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2011 at 12:14am
It's not the group delay as it only displays how long it takes till the signal will be coming out of the system. It can be compensated by delay as long as the group delay over frequency diagram won't be a wild ride around the crossover frequency. It is the decay time of the resonator. A resonator is a very high Q system, that means energy will be stored in and then put out of the resonator, and this won't happen in an instant, especially the "puting the energy out" will take some time AFTER the original signal stopped and even AFTER group delay time has passed. What a resonator does to the original signal is NEVER a good thing, it's always a degradation. Below 60, 70, 80Hz it is acceptable, but still not great. Above 80Hz it's just ugly compared to real "kick bins".
Most double-12 tops are tuned to 80Hz or below, and crossed over around 120Hz. That's ok in my opinion, still there is coming some "noise" coming from the resonator. Stuffing the port for top usage comes to mind. Ported tops tuned to 100Hz or above are just flawed designs, I wouldn't like to use them at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PolymorphicMark Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2011 at 1:26pm
Thank you very much JD01 for taking the time to write such an informative answer. I fully understand what you are saying now, always nice when learn something meaningful.
fourway hornloaded View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fourway hornloaded Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2014 at 8:26pm
I agree with Mark, the driver should have a Qts around 0,3 and a lowish BL around 23, that makes the response nice and smooth. I think that the 0,2 Qts high-fs drivers that Johan mentions are more for pure horns without a front chamber. They'd make a peaky response in a BPH. I made a pair of 6th order BPH based on L15P200AK, but they were rather aimed at low extention.
As to 'real kick bins': they're all 4th order band pass horns, Turbo TMS, F1, HD15, so if you like that sound, go for it. They all have front chambers, otherways they wouldn't play that low. A straight 15" horn without a front chamber kicks like madness (think Martin MK1) and I can understand that people find that sound way better than a BPH, but then the only thing that makes it play lowish (70 Hz) is horn length.
This page was generated in 0.105 seconds.
