  New Posts New Posts RSS Feed - 7 laminates ply birch instead of 13 laminates
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2021 at 6:16pm
Are you sure this ply does not have a phenolic face, such as the shiny brown faced flightcase material favoured in Germany? Im guessing as you stated BB/BB it does not, but best to check. Other than that should be fine
Check out sheet material wholesale on google, minimum £500 order, but good prices and they deliver
heavydub View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote heavydub Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2021 at 6:46pm
yeah, no brown faces. As I told, the seller said that the only difference is the glue used between each laminate. And I can confirm again quality is BB/BB. Moreover, provenience should be Sweden.
The seller is a wood seller, don't know nothing about speakers. He just said that for external usage he advice phenolic panels. If you are using it for internals, the simple birch without phenolic glue should be just fine.
But now normal is not available and panels dimention is smaller than the phenolic one.
I'm in a hurry so I guess tomorrow I will buy phenolic panels. I will post pictures of them.
Edited by heavydub - 07 July 2021 at 6:48pm
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2021 at 9:32am
I haven't used it but you might find phenolic board doesn't take glues the same way as regular ply. I gather it is very waterproof so might not absorb normal water-based wood glue very well.
This page was generated in 0.326 seconds.
