8"+1" |
Post Reply | Page 123 8> |
dlyxover
Old Croc Joined: 14 June 2007 Location: Liverpool Status: Offline Points: 1508 |
Posted: 26 April 2015 at 2:10pm |
I managed to get some time to do a little prototype of a 8"+1" cab.
Im quite pleased with the results, want to do a few tweaks tho. I gave it quick smaarting, to see when its at and as a reference for post tweaking measurements.
Dark red =LF, Blue=HF, Green= resultant Edited by dlyxover - 26 April 2015 at 2:13pm |
In the Truth there is no news, and in the News there is no truth
mini-mad
Very cute!
I assume its the prototype as even little 18mm MDF boxes weigh a bloody ton! what drivers are we using in this project? And are we gonna try for a passive in them so you wont need to bi-amp? |
dlyxover
Indeed used MDF as it the prototype but planning on using 18mm ply for the finished units.
I've used a Fane sovereign 8 225 and a BMS 4524 on a Faital STH100. Indeed also planning on a passive and maybe a 12" sub to sit under them.
dylan-penguinmedia
Old Croc Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4576 |
For a little box, you'd probably be ok with 15mm - unless of course you have some 18mm knocking about - with smaller panels and less stresses from the drivers, your back will thank you for it one day :) |
kr1sounds
Young Croc Joined: 28 June 2014 Location: ThePromiseLand Status: Offline Points: 920 |
Thanks(1)
could do with a pair of these in my room
fostonshfs.webs.com |
MarjanM
By looking at that graph i would not like how it sound. i like tops to sound bright and sparkling in the high end.
dlyxover
I do have enough 18mm lingering about to make 4 of them. It weights 10kg at present but also like the idea of over engineering them bit tho.
dlyxover
It was a quick smaart job as I said. As we all know plots can be misleading but thanks for opinion MarjanM |
T-Bone
Registered User Joined: 27 December 2005 Location: Tampa, FL USA Status: Offline Points: 292 |
I have Beta 8 A laying around will that driver work + B&C DE120? Thanks nice work would love to build these passive crossover with a Tham 12 loaded with 3012LF. I need something for smaller parties quick setup (100 peeps).
BASS, how low can you go!
dlyxover
Give it a go. I've done the cab to suite the driver and the passive crossover will also be suited to the cab and driver combo.
T-Bone
Do you have plans I would build these 15 mm I have 2 X 48"X96" BB in my garage. Also will your passive crossover work with my combo as stated above? Can you put up a video on youtube how it sounds your current build rpototype? Be waiting thanks!
dlyxover
After a bit of listening I though the sound was bit looser/slower that I'd like.
To tighten the sound I cut the port down to tune it a little higher and added more dampening. It lost a few Hz of low end but resulted in quicker/punchier sound to my ears. Gave it another quick smaart so see where its at. Red=8", Yellow=1", Blue= resultant (Green=previous resultant) For the passive crossover I'm starting to think of doing a simple crossover and use DSP to optimise the enclosure (in a next style) |
