  New Posts New Posts RSS Feed - 8" mid horn plan
8" mid horn plan
ychole audio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ychole audio Quote  Post ReplyReply Direct Link To This Post Topic: 8" mid horn plan
    Posted: 28 July 2007 at 9:21pm
  Anyone got plans for 8" mid horn?Thank you very much.
I am ZERIEL'S dad!!!
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 29 July 2007 at 9:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ychole audio Quote  Post ReplyReply Direct Link To This Post Posted: 29 July 2007 at 10:40pm
        Thanks!Nice design & looks good too.Lots of woodworking tho!!
moray james View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote moray james Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2007 at 6:44am
Check out what Adrian did with the somewhat smaller driver. Easy to build and should give you good results. You can scale the design up to fit an eight inch driver.
moray james
TONY.A.S.S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2007 at 8:41am
I think a small mid horn may be easier than you think. One approach could be to decide the length, i.e. throw. Decide how wide you want the box to be. Then decide your angle of dispersion. This will give you your termination angles. Make the throat smaller than the piston diameter. All you have to do now is fill in with two lines 1 for vertical 1 for horizontal. If you need to squeeze hi end out, keep the throat fairly tight. A faster flair rate from the throat will give you a more mellow sound. For our own use, we build fibreglass 8" mid horns. Once you have built the first horn, If your happy, it's easy to make a mould out of it and do them in glass. Only a thought.
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 30 July 2007 at 11:07am
tony that was inspiring..........
i learn a little more every day,
cheers [again]
markk
horn loaded for her pleasure
