Post Reply | Page <123> |
shagnasty
The ultra drive is fine, powersoft amps aren't a ballsy as QSC PLs and s/hand turbo is big bang for buck..
I have run 21s under tms 4 in the past in a 125/30 band and IMHO the depth of the 21 is better than the TSE, but I have also used my 718s with my tms 4 and IMHO the 718 has the same depth as a single 21" with a lot more punch.
With secondhand 721 going for as lo as £500+Vat they are a very tempting option, ideally run off a PL 6.0 or better....
I am told the funktion 1 121 is pretty much equal to 2 turbo ones and uses neo mags so more back freindly...
I have just built 2 1/2 718 boxes to sit under my tms4s and they are having there first outing tommorow.. Upstair gig my decision to use 15mm not 18 makes me so happy..
simo69
Old Croc Joined: 29 September 2005 Location: United Kingdom Status: Offline Points: 1890 |
We tried the TSW721 copy box and WOW!!! Only on a full range signal ... but still WOW!!
TSE218 vs. TSW721 side by side comparsion will be performed a.s.a.p...
csg
i seem to remember turbo recommending using the tsw124 with tms4's. anybody tried this?
they were large.....
shagnasty
Yeah, I've used them... Very lo, warm, gutsy...
But HUGE! and to be honest not one of turbos finer moments, most were load with a fane driver that was notorious for magnets slipping on it. I don't know if they ever sorted this or went to a PD driver but to be honest these boxes are not good at fast bass at all, the 21 got sl*gged for this but if you don't run it out to 180 hz (flash/flood spec) it is fine, the 24s were real lo shakers, used them under tms-3s run off QSC EX4000 and they do produce some serious lo end but not a practical touring or giging box I feel.....
Dave M
Registered User Joined: 12 December 2007 Status: Offline Points: 144 |
I would suggest this... use the TSE 218s as a bass cab 80Hz upwards with the 21's underpinning them handling sub freq. 24.8 Hz butterworth- 80Hz Linkwitz. If your TSE 218s have the original LS1802 3" voice coil PD manufactured drivers they are a bit weak and do tend to suffer from failure with 'modern' dance music program. You could try replacing these with a PD188 which is quite similar to the turbo LS1804 used in the 718 bin which has double suspension and 4" voice coil. There is also an issue with that the 2 18" share the same cavity within the enclosure, The TSE 118 overcomes this and multiples of these sound far better than the dual versions. Maybe try adding some time alignment say 1-2ms on the 21's. or just use the 21"s upto 90Hz with the TMS 4's or 3's with a big amp (900W per driver min) as the voice coil mass on the 21" driver is massive and needs plenty of power to get them going.cheers
dave
H..
Registered User Joined: 07 August 2007 Location: Thailand Status: Offline Points: 197 |
PD184 - Rout the handles on your TSE218 - CHECK the holes line up on the T nuts!!
XTA - THE ONLY WAY
FFA Amps
1:stack the bins so mouths sum ie make one big mouth
2:Don't butt the TMS4's together you need about a 4" gap between the fronts with the backs touching
3: TMS3 & 4 have completly different path lenghts - except the 10" mid - DON'T run them together unless on different drive / amp channels so you can time align them
Have fun
Dave M
is that you mr smart?
Dave M
H..
maybe
simo69
Edited by simo69 - 05 January 2008 at 3:15pm |
simo69
We trialed the TSW721 with a TMS3, the cabinet was loaded with a MKII PD21" driver.
The result was the cabinet loving anything from 35 to 150hz. . and me having some ear wax removal from the spl ... tested in a friend house.
I am having a second cabinet made next week to trial a pair. . keep ya posted.
simo69
Replace all my 18" drivers with PD188..?
... thats 12 drivers as I have 4 TMS3 and 4 TSE218..
