  New Posts New Posts RSS Feed - .
cyte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cyte Quote  Post ReplyReply Direct Link To This Post Topic: .
    Posted: 03 September 2009 at 9:30pm
Edited by Corticyte - 08 November 2010 at 12:15am
adambomb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote adambomb Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2009 at 10:07pm
How the hell did you get the Stasys X plans? Rog gunna be mad!!
cyte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cyte Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2009 at 10:46pm
haha, do you think he'll believe me that I came up with this plan myself? I can't believe its THAT similar to the stasys X. I'd quite like to build it without infringing on his patent!!
Edited by Corticyte - 03 September 2009 at 10:56pm
minaximal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote minaximal Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2009 at 11:08pm
your lower ported chamber will act as a helmholtz absorber, and would be effective to take a peak out of the combined response in the short and long horns.
it will not produce higher frequencies, and getting the two horns outputs in phase is almost? impossible.
unless you can simulate or know the maths and are a good guesser, the design as is above would be a pig to proto and get sounding nice.
but why not have a go, and see what you think.
p.s. good luck
Subs + Barges = :)
www.metaacoustics.com
cyte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cyte Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2009 at 11:25pm
I thought it might do that, but I didn't know it was called a helmholtz absorber! thanks.
As for prototyping, i'm probably going to try some serious simulation and maths before I go anywhere near a saw. This is more a learning exercise for me than anything. I designed a simple band pass sub a while ago and learnt a LOT from that, so now i'm stepping up my game a bit!
thanks for the help
fuzzylogic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fuzzylogic Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2009 at 12:36am
Do the maths ,get some dimensions going on,and there is a saw and three sheets of ply at the workshop with your name on it!
NEIGHBOURHOOD SOUNDSYSTEM
Infinitely baffled.
cyte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cyte Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2009 at 12:56pm
nice one! it'll probably be a while before I come up with a working plan though! What time are you loading up today? Give me a shout.
Taterworks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Taterworks Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2009 at 4:10am
This looks like something you'd need Akabak to simulate. Hornresp can do combined back and front horns, but I've never played around with that functionality.
Edited by Taterworks - 18 September 2009 at 4:10am
The Gearmonger
ericlee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ericlee Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2009 at 7:12am
Good! Design is good!
bitzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2009 at 11:02am
you can with compound driver arrangement. But for the 3 chambers vent you need akabak at all.
cheers, bitzo
char355 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote char355 Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2010 at 3:01am
Did this project ever go any further?
its similar to something I've been thinking about.
I've never seen the inside of the stasys x but i suspect my design is very similar, how close can it be without getting in trouble?
FlipC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FlipC Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2010 at 6:14am
I wouldn't worry about it to much less you cut one up and copied it per bat-em.
Not like the HD15 or the C, G, etc are original. Just a known design arranged for specific driver.
