Post Reply | Page <123> |
jethrocker
Old Croc Joined: 07 June 2006 Location: Chiapas, Mexico Status: Offline Points: 1942 |
just accept it... most of us here are going to damage our backs, our ears and our finances for sure.
But seriously, go steady, sciatica hurts. A lot.
Tekasis
Old Croc Joined: 03 July 2006 Status: Offline Points: 6492 |
It they do the job, I wont complain.
see:
Tom Umney
Registered User Joined: 26 February 2004 Location: United Kingdom Status: Offline Points: 4954 |
Personally with scoops I'd never lift them. Just drag them around on the castors. Or maybe lift them between 2-3 strong people.
jethrocker
Sometimes you just have to lift them.
Up stairs, into the van etc(unless you're fortunate enough to have a decent van with tail lift-too poor for that, maybe I can get something cheap off shortman?)
Jay Lawless
Old Croc Joined: 22 August 2005 Location: United States Status: Offline Points: 1702 |
Jethrocker - exactly why i mentioned "light weight" to you in PM ! haha
Background: Automotive, Live and Home Custom Design. mid/high level based design and feild experience. Bass specialist |
Nigey-C
Registered User Joined: 06 February 2006 Location: Grimsby... FISH Status: Offline Points: 1342 |
Jethrocker - Use a Ramp?? addin a tail lift to your van will only mean you can carry less gear in it!
djstefanos
Old Croc Joined: 18 November 2005 Status: Offline Points: 2355 |
sell your van, buy a japanese one that has a very low trailer at the back. about 2 feet off the ground
jethrocker
I did mention the financial issue..so what makes you think I could afford to import a van from japan?
yeah, could use a ramp..but when you're trying to get six superscoopers, several large racks, and all the rest into a hi-top trannie lifting (of the awkward, twisted damaging kind) is inevitable.
Tobin
Registered User Joined: 06 March 2005 Status: Offline Points: 209 |
Just a quick question. Im about to build the Super Scooper, it all seems quite obvious except the front support; if you look at the mouth at the front their is the vertical support and a horizontal one (making a + cross). I can see how the vertical one screws in but is the horizontal one only screwed to the sides and not to the centre vertical one? I don't see how you could screw it, maybe do one side, but once thats in how do you do the other side?
Toby |
jethrocker
Yep, it's tricky.. depends on the order of the rest of the build, but generally there will have to be one joint without screws.
When we built ours the cross went in before the side went on..we made the horizontal one piece straight across, with routed channels to take the upper and lower sections of the vertical (they need to be cut spot on)..
The top section will slide in and can be screwed from the top from inside the chamber down. as the bottom section is already home and screwed top and bottom you can then clamp between the driver cutout and the horizontal to pull it type while the glue sets on the top peice.
I spent alot of time bending my mind on this..there are other ways but not really anyway to do it without one joint going without screws. The only way would bve to build the cross outside the box, then fit it whole and screw from all four directions..but difficult to keep it all square and accurate that way.
Tobin
Hmmm, i think some clever routing is in order. Problem is i don't own one, meaning i haven't had much practice with routers. I guess i could do a few practice joints and just plan it out carefully.
Did you ever consider putting a slot half way though both the vertical and horizontal so they slot together? A and B both have the slot so they can slide together (you can only see cross-section of B): You still couldn't screw them but presumably with glue it would be pretty damn strong? Because of the nature of the joint you would have good strength on both axis... Edited by Tobin - 15 October 2006 at 9:35pm |
COWFOOT
Registered User Joined: 26 September 2005 Status: Offline Points: 1088 |
You can use the pocket-hole screw technique. KREG makes a pocket-hole jig. Google. Used to attach table tops to rails is a popular use.
