  New Posts New Posts RSS Feed - A Proper Vintage Power Amplifier
audiomik View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiomik Quote  Post ReplyReply Direct Link To This Post Topic: A Proper Vintage Power Amplifier
    Posted: 11 March 2011 at 11:58pm
Spotted this link over on the Blue Room but think it deserves posting here as well!
1955 Valve Amplifier
Like the idea of the sympathetic Light Show from the Mercury Arc Rectifiers and the 3 phase supply it needs
Mik
Warning! May contain Nuts
plus springs, washers, screws, etc, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2011 at 9:06am
Thats an interesting read Mik....love the bit at the bottom of the specs...weight..142kgs per channel!
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiomik Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2011 at 1:32pm
well, it certainly makes the Amplifiers with conventional Power Supplies using transformers into 'light-weights'!
Not to mention that it's 56 years old and still running
an internal pic of the EL6471:
but even better still a copy of the full service manual - mostly in Dutch
Philips EL6471 Service Manual
uses only 2 valves for the output stage
anyone fancy building a couple of these then - 'monoblocks' were being discussed in other threads and this certainly fits the bill
Mik
Edited by audiomik - 12 March 2011 at 1:44pm
Nitz V1505 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nitz V1505 Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2011 at 3:46pm
One of my dream amplifiers along side the GEC 1100w amp using V1505's. Also a big fan of multiple KT88 push pull parallel class B amp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiomik Quote  Post ReplyReply Direct Link To This Post Posted: 12 March 2011 at 9:39pm
Re: "Also a big fan of multiple KT88 push pull parallel class B amp."
just wondering how many KT88's would be needed, with all of the additional associated bias balancing, compared with a pair of QB3.5-750's running with an HT of 3.2kVolts or even something more modern in terms of decent high power Tetrodes rated at 1250 watts (or more) dissipation each?
Datasheet for the QB3.5-750 output Valves used in this Amplifier at:
QB3.5-750
...........so the comparison can be done
Do like the overall simplicity of this EL6471 design, and the Mercury Arc rectifiers certainly have an 'visual interest factor' much greater than a bunch of silicon diodes!
Reminds me of when I used to use surplus 813 Transmitter Valves; for building Amplifiers in the '60's
Mik
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nitz V1505 Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2011 at 1:32pm
You would need 10 pairs of KT88's ,preferably matched, to produce 1000watts. You could also use a single bias supply to simplify the circuit. The psu would have to provide atleast 575V at around 2.5A, newer versions of the Kt88 however can take up to 800V on the anode. This is a cheaper method of obtaining 1000watts  because of the cost of more expensive valves.
Edited by Nitz V1505 - 13 March 2011 at 1:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2011 at 1:43pm
To quote from the link posted by Mik
"The EL6471 was designed for use in large stadiums and possibly concert halls and was never mass produced. Its final tubes are types QB3/750 beam tetrodes originally developed for transmitters. In good Philips Holland tradition, they are run “conservatively”. In the EL6471 product sheet Philips also mentions 2 kW, 10 kW and 20 kW versions of the amplifier (price on request)."
The 20kw version must have been the size of a small shed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nitz V1505 Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2011 at 1:55pm
And probably designed for speech/PA in stadiums, 300-1000hz at a guess. Otherwise to produce real low frequencies I'd say the the o/p transformer would be the size of a shed!!!!!
Edited by Nitz V1505 - 13 March 2011 at 1:56pm
Muckerbarnes1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Muckerbarnes1 Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2011 at 9:45pm
I love valves. Grew up with them. Still fix some valve amps. Got a couple of weird 35W ones here called Fantavox.
Never seen an EL6471 though.
Billy Dawg.
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiomik Quote  Post ReplyReply Direct Link To This Post Posted: 13 March 2011 at 11:21pm
Ok, just when anyone thought that building a replica is off; up popped this site:
Royal Navy Type 182 Final Amplifier and Power Unit
Quote: "For the High Voltage & High Energy experimenter, these units contain many useful parts. See photographs and descriptions of the components used in these units. Once stripped, these components may be re-used for a wide variety of applications"
Do like the idea of deterring Torpedoes though - being quite a few miles from the sea and for an HF Amplifier; unmodified it might never be 'beaten'!
Think we already know manufacturers of suitable output Transformers, which looks like being the only main part 'missing' for quality full range Audio
Some years ago I would have had a go at this sort of Project; but I just don't have the necessary space or facilities any more
Mik
Post Options Post Options   Thanks (0) Thanks(0)   Quote Muckerbarnes1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 March 2011 at 7:08am
Fortunately dettering torpedoes at the high ground here will not be any advantage either. Smile
A great way to heat the workshop on a cold day. Proper audio visual display too.
Billy Dawg.
TONY.A.S.S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 14 March 2011 at 4:15pm
These are not vintage, but they are very good sounding chinese valve amps, 80 watts per channel. As a lot of people will know, valves are still very popular in the Hi Fi business.
Uploaded with ImageShack.us
