A Recone Guide |
Post Reply | Page <1 78910> |
Awesomesound99
Registered User Joined: 10 June 2013 Location: London Status: Offline Points: 24 |
Awesome guide, very useful!
APC321
Young Croc Joined: 24 August 2013 Location: West Midlands Status: Offline Points: 680 |
Just discovered the recone guide. Very useful source of info.
cass ent
Registered User Joined: 08 February 2014 Status: Offline Points: 12 |
This is very informative . My advice to any pa enthusiast / bass junky / speaker freak , is to give it a go . I did my first recone 11 years ago on a fane colossus 15xb and I've never looked back since . I've done over 500 recones / foam edge repairs now and it can be very addictive ! I'll get baskets just to repair them sometimes( it beats an airfix kit any day)
Some clone kits require abit of prep work but I never rule them out as you can save a hell of a lot of wedge over a genuine kit and to be honest you would be hard pressed to tell the difference in tonal quality and most of the time physical look. |
Jubone
Registered User Joined: 12 May 2013 Location: UK Status: Offline Points: 34 |
Hi there,Thanks very much for the info.I'm doing a recone myself to an old Celestion 18" bass driver that has had a rattle since buying it on ebay,It's part of a Tannoy B950 cab. I waited for the kit to arrive before stripping out the software on the driver. As soon as I had removed the old cone assembly I covered the voice coil gap with tape and spent a good few hours preping the driver for the new software, when I finally removed the tape to clean the gap I noticed that the gap is slightly offset. To verify my visual observations I put several of the shims together so they was a snug fit in the gap and ran round 360 degrees, and sure enough it got tighter on one side. So I imagine that it is game over for this driver, and it would be a waste of a recone kit to confirm my suspicions? Any suggestions would be welcome.
Edited by Jubone - 21 May 2014 at 6:10pm |
brokenjoe
Old Croc Joined: 31 May 2009 Location: Birmingham Status: Offline Points: 3722 |
does the new kit go in freely?
error 404
Jubone
Hi Joe, with all the shims in place it's a tight fit, need a bit of pressure to push the coil into the gap. Looking at the old voice coil there doesn't appear to be any damage from rubbing.
brokenjoe
with the shims it should be pretty tight, especially the last one but you shouldn't have to force it..
i'd say if, without the shims in, that it moves fairly freely it should be ok.. i'd do the recone if i were you |
error 404
Jubone
Ok, I'll try another dry run. On the previous one I had all the shims in place first and then eased the cone into place, so your saying put the cone in and then put in the shims, I'll give that a try on a dry run then. Thanks for that.
brokenjoe
no, i mean if it goes in and can move freely without the shims i'd have thought it'd be ok..
error 404
Jubone
Yeah, got ya
Jubone
Thanks Joe and to everyone else who took the time pass on their wisdom on this forum. I went for it and the driver is working again. :)
midas
Old Croc Joined: 27 October 2011 Location: Cumbria Status: Offline Points: 2117 |
Has anyone used Gorrila glue on spider and basket? Or shall I pop to screwfix for some Evostick?
