above 4 scoop... |
Post Reply | Page <1234> |
bitzo
Registered User Joined: 20 November 2007 Location: Italy Status: Offline Points: 977 |
double ported wbin? |
silworm
Registered User Joined: 28 September 2004 Location: Portugal Status: Offline Points: 271 |
Ok Levyte, this PD1550 was sugested to me by JTS as a good driver for a reflex enclosure, but I'm glad to know that they can work well in a horn too. What horn are you referring to?
This way I might start with a simple design and maybe move to horn in the future without having to swap drivers. |
king david
Young Croc Joined: 17 January 2007 Location: italy Status: Offline Points: 1324 |
for pure upper bass b&c 15plb76...as ceharden suggests here in the end i built es18 bandpass horns, they are ok, a bit too big and heavy for 1 man lift but do the job very well, nice bass, nice throw, a bit strange when you are very near the stack.
if i would just need a box to just play dub, i would build reflex, good for small places, good for bigger ones when fed with enough power, easy to build, and yes not funny but i'm not funny anyway... Edited by king david - 23 February 2010 at 5:14pm |
_Natty_
Young Croc Joined: 01 April 2007 Status: Offline Points: 663 |
but he sayd also that the nw76 doing the job better with some more power...or i wrong?
Edited by _Natty_ - 24 February 2010 at 8:47am |
_Natty_
first test....
king david
looks great!!! a stack like this would really give justice to roots/dubwise!
only thing i must add is...100hz hpf on the jbl is too high, i'm sure they kick hard!
tweeter box
Old Croc Joined: 21 October 2007 Location: United Kingdom Status: Offline Points: 6784 |
looks wicked
cross to the JBL midbass at 85hz
bitzo
_natty_ have you load the wbin with a double 15" or a single 18"?
joseph
Registered User Joined: 20 May 2007 Status: Offline Points: 228 |
i use the b&c 15 box , simple box , on my 4 way system , playing roots & dub ... very very good cabs !!
see in myspace/jahmilitant , photos section, cultural dub temple II ... just build dem recently and it was the 1st time i played with those kick box ... very good results , loaded with fane .
respects
weeda
silworm
joseph, what is the fane model you use and what are the crossover points? thinking of building something similar...
_Natty_
nice stack joshep!
the jbl are loaded with a single 15" soon i'll open the box and i'll see wich bc driver is...and maybe i'll put one new....this test is made quikly in one session...and it sound great... @tweetr box. actually i can't change my crossover point...mostec style ;) |
_Natty_
we have some problem of times for make a building so we continue some test!!!!
with celestion 18" sub....cut off 200hz... |
