  New Posts New Posts RSS Feed - access and baffle
access and baffle
Aawoodz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aawoodz Quote  Post ReplyReply Direct Link To This Post Topic: access and baffle
    Posted: 17 September 2009 at 9:52pm
hi guys and girls i have read through loads of topics and cant find what im lookin for, what size should tha access planel be and what size should tha baffle hole be as i havent got tha driver yet. driver will be a PD 154
Silas )))))) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Silas )))))) Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2009 at 10:20am
have a good look at the plans its all there. Best thing to do if your not sure is draw a scale drawing to get it figured out. The access panel you will want to be as big as possible. Aim for at least 16-18" across the diagonal of the hole.
Hope this helps p.s the baffle is 420mm
power in the blood
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aawoodz Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2009 at 4:23pm
isnt 420mm that lenght of tha baffle? i want to know tha size of tha hole to put in tha baffle
Post Options Post Options   Thanks (0) Thanks(0)   Quote Silas )))))) Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2009 at 7:03pm
There should be the exact size of the driver on the its spec's page.
Or better, wait get 'tha' drivers and then cut 'tha' baffle hole.
Edited by Silas )))))) - 18 September 2009 at 7:05pm
power in the blood
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aawoodz Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2009 at 2:01pm
ok thanks for THA info, i will try THA spec's page
Post Options Post Options   Thanks (0) Thanks(0)   Quote Silas )))))) Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2009 at 2:19pm
Thumbs Up
power in the blood
