Actually Building a PC |
Page <1234 5> |
joshd963 ![]() Registered User ![]() Joined: 09 September 2009 Status: Offline Points: 375 |
b3n ![]() Registered User ![]() Joined: 28 September 2008 Location: Brighton, UK Status: Offline Points: 222 |
I dont think I have ever used an anti-static wristband in years of building PC's
Might explain why I have had parts die on me though! |
Matrix XP3000H, Thomann TA1050, Peavey CS1400, QSC RMX1450
2 x Eminence Kappa and PSD2002 loaded x15's 2 x SN-15MB and BM-D450 loaded X15's 2 x V18-1000 loaded 1850's Behringer DCX2496 |
odc04r ![]() Old Croc ![]() ![]() Joined: 12 July 2006 Location: Sarfampton Status: Offline Points: 5483 |
I just touch a grounded point (radiator pipe etc) before I start and don't build them in carpet covered rooms
Admin ![]() Admin Group ![]() Forum Administrator Joined: 01 October 2003 Status: Offline Points: 1677 |
I do have anti static wrist bands in my tool kit, but never use them.
I do the same as odc04r stay away from carpets and sometimes if I remember touch a grounding point. Considering I am often taking apart £5,000 plus servers I really should start wearing one. Edited by bruce - 14 January 2010 at 5:30pm |
norty303 ![]() Old Croc ![]() ![]() Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 8806 |
Same here, never used an antistatic band.
I normally install the PSU first, and then plug it into the power socket but turned off. You now have the case grounded. I just make sure I touch the case periodically whilst working, but as you're normally rooting round inside anyway, it's fairly hard not to ground yourself. I've never killed a component so it must work.... ![]() |
bassmish ![]() Young Croc ![]() Joined: 28 October 2007 Location: MAAAANCHESTER Status: Offline Points: 1333 |
that's what I would have done norty
got me a wristband today tho, to be on the safeside. although I can'T SAY i really understand how it's gonna be any help... I wish the postman would hurry up and bring me the rest of my dubmachine! |
Calculus ![]() Young Croc ![]() Joined: 03 January 2005 Location: Newcastle Uk Status: Offline Points: 1105 |
do you not need heat sink compound when fitting the fan to the processor???
Most coolers will come with a heat compound pad preapplied. Performance is not usually as good compared to if you were to remove it (scrape it off + acetone) and reapply a smaller amount of higher quality paste I find. Certainly does work though.
cool just wondered.. the white stuff is apparently a silver oxide paste.... I reset the prossessor in my laptop with some and cleaned the fan best thing i ever did with the laptop after two n half years it was full o dust...made it run like new again.
same stuff between chips on amps and the main heatsink if you ever wondered what the white gloop is.
aargh!
I just got my mother board and precessor, so I'm gonna start uilding right away! BUT.. I have no keyboard!! bugger |
Page <1234 5> |
