  New Posts New Posts RSS Feed - Actually Building a PC
 Post Reply Post Reply Page  <1234 5>
joshd963 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshd963 Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2010 at 10:52pm
b3n View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote b3n Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2010 at 4:17pm
I dont think I have ever used an anti-static wristband in years of building PC's
Might explain why I have had parts die on me though!
Matrix XP3000H, Thomann TA1050, Peavey CS1400, QSC RMX1450
2 x Eminence Kappa and PSD2002 loaded x15's
2 x SN-15MB and BM-D450 loaded X15's
2 x V18-1000 loaded 1850's
Behringer DCX2496
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2010 at 4:28pm
I just touch a grounded point (radiator pipe etc) before I start and don't build them in carpet covered rooms Smile
Admin View Drop Down
Admin Group
Admin Group
Forum Administrator
Post Options Post Options   Thanks (0) Thanks(0)   Quote Admin Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2010 at 5:30pm
I do have anti static wrist bands in my tool kit, but never use them.
I do the same as odc04r stay away from carpets and sometimes if I remember touch a grounding point.
Considering I am often taking apart £5,000 plus servers I really should start wearing one.
Edited by bruce - 14 January 2010 at 5:30pm
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2010 at 5:36pm
Same here, never used an antistatic band.
I normally install the PSU first, and then plug it into the power socket but turned off. You now have the case grounded. I just make sure I touch the case periodically whilst working, but as you're normally rooting round inside anyway, it's fairly hard not to ground yourself. I've never killed a component so it must work....
bassmish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bassmish Quote  Post ReplyReply Direct Link To This Post Posted: 14 January 2010 at 5:58pm
that's what I would have done norty
got me a wristband today tho, to be on the safeside. although I can'T SAY i really understand how it's gonna be any help...
I wish the postman would hurry up and bring me the rest of my dubmachine!
Calculus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calculus Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2010 at 8:21am
do you not need heat sink compound when fitting the fan to the processor???
Post Options Post Options   Thanks (0) Thanks(0)   Quote joshd963 Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2010 at 8:47am
Should come with that on it.. The White stuff you mean?
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2010 at 10:47am
Most coolers will come with a heat compound pad preapplied. Performance is not usually as good compared to if you were to remove it (scrape it off + acetone) and reapply a smaller amount of higher quality paste I find. Certainly does work though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calculus Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2010 at 11:08am
cool just wondered.. the white stuff is apparently a silver oxide paste.... I reset the prossessor in my laptop with some and cleaned the fan best thing i ever did with the laptop after two n half years it was full o dust...made it run like new again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calculus Quote  Post ReplyReply Direct Link To This Post Posted: 15 January 2010 at 11:09am
same stuff between chips on amps and the main heatsink if you ever wondered what the white gloop is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bassmish Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2010 at 2:19pm
aargh!
I just got my mother board and precessor, so I'm gonna start uilding right away!
BUT.. I have no keyboard!!
bugger
This page was generated in 0.046 seconds.
