  New Posts New Posts RSS Feed - Admark CD8000
Admark CD8000
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2023 at 7:41pm
is the same design the SAE PQM13 but better build quality than the current SAE amps.
yodominic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yodominic Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2023 at 8:13pm
Not an expert in Chinese amps but if they are SAE equivalent then it should be decent enough, price wise how much are they worth
dlyxover View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2023 at 8:44am
I have a SAE PQM13 and PCM18, have been running both a 4ohm with no issues for the last 8 years.
I have a Sinbosen fp20000Q incoming in the next few weeks, claims to produce 4x4K at 4ohm
Will be interesting to see how its stands up.
In the Truth there is no news, and in the News there is no truth
turbo7 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote turbo7 Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2023 at 12:25pm
Originally posted by yodominic yodominic wrote:
Hi All
I’ve been offered an Admark CD8000 amp, it’s a 4 Channel amp but I’m hoping to drive a 2 * dual 18’’ loaded cabs. Has anyone used these amps and your experience and reliability issues is much appreciated
Thanks
Just don't expect the amplifier, to output quoted specs.
Even with the most respected makes of these amps, I would only expect max 50% of rated output power, in 40hz-100hz range.
Remember even the illustrious Powersoft X8, is not recommended for sub usage, on every channel.
Exactly this !
