  New Posts New Posts RSS Feed - Admark K30
Admark K30
 Post Reply Post Reply Page  <1234 11>
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2021 at 6:49pm
If you want excellent HF performance from a D class amp, you should try the PKN.
M4trix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M4trix Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2021 at 10:27pm
Quote:
Be able to work in stereo,paraleel and bridge mode.
How can you trust a company that has such errors/mistakes on their website !? Tongue
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2021 at 10:58am
I am content with the QSC playing ultra high frequencies. It was more to wards a possibility of seeking the CVR (Class D amplifier) 3002 for tweeters.
Not a bit concerned about typographical errors for, Admark did not build the amplifier. Admark just branded their name on the amplifier. Once you are looking to buy quantity, there is an option to add your company name on the amplifier.
I am buying directly from the source in March.
Best Regards,
djhrh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djhrh Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2021 at 8:46am
So, does anyone own the admark yet? Give us a review!!
djxcel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djxcel Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2022 at 7:26pm
Check Out These 2 Videos
https://www.youtube.com/watch?v=AhHi5U-c6DY
https://www.youtube.com/watch?v=1APaYy8YHyg
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2022 at 7:40pm
All i understood from these two videos is that all amps works and plays some tone.
T Willy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T Willy Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2022 at 2:13pm
I have one on order now. Ad42. Will be here mid/late March.
Justus_Jonas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justus_Jonas Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2022 at 9:46am
@T Williy
any updates/experience with the ordered ad42?
Regards
Edited by Justus_Jonas - 03 June 2022 at 9:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote T Willy Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2022 at 2:03pm
Originally posted by Justus_Jonas Justus_Jonas wrote:
@T Willy
Regards
Yes, absolutely! It has been nothing short of fantastic! More then enough power for my needs. Hasn't skipped a beat as well. I'm using it at 4 ohms parallel to run 4- PFX C2e Silver formulas. The PFC is excellent as well. It doesn't miss or cut out when ran off a generator either. Highly recommended! In fact, i'm most likely going to sell my m50q later on this fall and pick up the matching k420 for my mids and highs.
taurusty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote taurusty Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2022 at 6:24pm
Good Afternoon,
Any developments, Elliott?
Looking to purchase Admarks new K /AD 430  (3KWx4 ch)
Anyone in here tried it yet?
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2022 at 8:34pm
Originally posted by taurusty taurusty wrote:
Good Afternoon,
same format as the 2kW*4ch version. photos show they have the same number and same rating capacitors. same number of output devices so must be a lot more power going through each one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2022 at 8:39pm
this page is interesting as it compares two of their high power 2 channel models giving some differences and similarities of components:
China K35 Class-D Rack Power Amplifier-2 Channel Manufacturers, Suppliers - Made in China - ADmark (admarksound.com)
This page was generated in 0.158 seconds.
