Admark K30 |
Post Reply | Page <1234 11> |
MarjanM
If you want excellent HF performance from a D class amp, you should try the PKN.
M4trix
Registered User Joined: 23 June 2009 Location: Croatia Status: Offline Points: 445 |
Quote: Be able to work in stereo,paraleel and bridge mode. How can you trust a company that has such errors/mistakes on their website !?
I am content with the QSC playing ultra high frequencies. It was more to wards a possibility of seeking the CVR (Class D amplifier) 3002 for tweeters. Not a bit concerned about typographical errors for, Admark did not build the amplifier. Admark just branded their name on the amplifier. Once you are looking to buy quantity, there is an option to add your company name on the amplifier. I am buying directly from the source in March. Best Regards,
djhrh
New Member Joined: 22 August 2015 Location: canberra Status: Offline Points: 4 |
So, does anyone own the admark yet? Give us a review!!
djxcel
New Member Joined: 22 January 2022 Location: New York Status: Offline Points: 1 |
Check Out These 2 Videos https://www.youtube.com/watch?v=1APaYy8YHyg
MarjanM
All i understood from these two videos is that all amps works and plays some tone.
T Willy
Registered User Joined: 07 February 2022 Location: Wisconsin Status: Offline Points: 43 |
I have one on order now. Ad42. Will be here mid/late March.
Justus_Jonas
New Member Joined: 21 August 2016 Status: Offline Points: 9 |
@T Williy any updates/experience with the ordered ad42? Regards
Edited by Justus_Jonas - 03 June 2022 at 9:46am |
T Willy
Yes, absolutely! It has been nothing short of fantastic! More then enough power for my needs. Hasn't skipped a beat as well. I'm using it at 4 ohms parallel to run 4- PFX C2e Silver formulas. The PFC is excellent as well. It doesn't miss or cut out when ran off a generator either. Highly recommended! In fact, i'm most likely going to sell my m50q later on this fall and pick up the matching k420 for my mids and highs.
taurusty
Registered User Joined: 09 January 2007 Location: Jamaica Status: Offline Points: 473 |
Good Afternoon,
Any developments, Elliott? Looking to purchase Admarks new K /AD 430 (3KWx4 ch) Anyone in here tried it yet?
snowflake
same format as the 2kW*4ch version. photos show they have the same number and same rating capacitors. same number of output devices so must be a lot more power going through each one. |
snowflake
this page is interesting as it compares two of their high power 2 channel models giving some differences and similarities of components:
China K35 Class-D Rack Power Amplifier-2 Channel Manufacturers, Suppliers - Made in China - ADmark (admarksound.com) |
