Advice choosing hog scoop driver |
Post Reply | Page 12> |
General Martok
New Member Joined: 17 May 2020 Status: Offline Points: 6 |
Posted: 17 May 2020 at 11:29am |
Hello! Im planning on building 2 18" hog scoops for a DUB and DNB soundsystem and im looking at 3 different PD drivers. PD.185NR1 PD.185C003 PD.1851/2 I was planning on going for the PD.185NR1 which is the more expensive Neodymium choice. But there are some differences (stiffer?) and now im not sure if this wold be better or worse.. Do you guys have any thoughts on this? Thanks! Daniel van der Meer
Edited by General Martok - 17 May 2020 at 11:33am |
Aurora
Registered User Joined: 31 July 2013 Location: Nottingham Status: Offline Points: 54 |
PD1851 is a good choice in hogs, stiff cone/high BL is ideal.
General Martok
Thanks! PD.185C003 wins in the BL spec tho so that one would be the best? are there other differences that would be of major importance?
levyte357-
Won't be much of a system, with only 2x Scoops
Next I saw no mention of sub amp. That needs deciding first. If you are contemplating cheap crap, no reason for pointless discussion about big man drivers.
Edited by levyte357- - 17 May 2020 at 4:45pm |
General Martok
Wasnt planning on buying cheap crap, your making alot of assumptions. was thinking about this: https://www.bax-shop.nl/versterkers/synq-digit-3k6-digitale-versterker#productinformatie and running 2 of em in bridge.
jacethebase
They don’t exactly look like the ideal solution bud. Unless there’s a fairly big secret with them I’d look elsewhere. What about a second hand Powersoft? K8 of k10 can be had for fairly sensible money now :)
www.stage2sound.com |
FOO
Young Croc Joined: 23 December 2018 Location: Denmark Status: Offline Points: 815 |
Eeeeh that Is cheap crap Good for driving small fullrange boxes. But not a powerhungry sub.. They barely can handle full tilt in 4ohm stereo. Really shait amps..
msoundsystem
Young Croc Joined: 10 November 2011 Location: wales Status: Offline Points: 625 |
If your budget wont stretch to powersoft then a Second hand vz5000 or crest ca18 will give u plenty of sub notes with the hogs pd 1851 loaded. As mentioned before. No point buying cheap amps for big boy drivers.
levyte357-
This. Maybe better buying 4x solid, used, well built hogs. Then maybe 4x used, mint condition 1851s. Then used, working CA18 or 5000VZ, or 2x Proline 3000 to bridge, and 1u limiter. Upgrade to K20, when gigs have paid for it.
FOO
Or even Better... Used macrotech 5000, and let your savings settle a little bit longer, and get a Lab PLM.. nighty-night to the powersoft and hellow to superb lows
And forget about running bridge. If you need more power, get more amps 🙂
Sonic the hedge
Registered User Joined: 12 May 2020 Status: Offline Points: 161 |
Care to explain how you load drivers onto more amps and get (significantly) more power, without using bridge mode? (Impedance vs output watts etc.) Think about it Edited by Sonic the hedge - 18 May 2020 at 4:36pm |
levyte357-
If he can Locate Void Infinite 8MK2, that would be plenty enough, for 4x Scoops, for 2x years, and then buy which ever big boy lightweight he wants. |
