  New Posts New Posts RSS Feed - Advice on building 2 way long throw cabinet
croes89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote croes89 Quote  Post ReplyReply Direct Link To This Post Topic: Advice on building 2 way long throw cabinet
    Posted: 19 January 2014 at 2:33pm
Hi guys,
I want to build a few 2way long throw cabinet.  (2x12mb 1x2hf)
I saw the speaker plan of the model mt122,but I have my own plan and I want your advice, if I should go with my plan or the mt122 plan to achieve my goal.
My plan contains:
1. 1x XR2064 (Constant Coverage HF Horn )
Website: http://www.eighteen.com/index.aspx?mainMenu=view_product_simple&pid=269 - http://www.eighteensound.com/index.aspx?mainMenu=view_product_simple&pid=269
2. 2x dmb 12n pro (mid/bass horn)
Website: http://www.ddshorns.com/BassMid%20DMB%2012N%20pro.pdf - http://www.ddshorns.com/BassMid%20DMB%2012N%20pro.pdf
all driver i'll be using will be 18sound
1. 1x NSD4015N (compression driver 2``exit)
http://www.eighteen.com/index.aspx?mainMenu=view_product_simple&pid=327 - http://www.eighteensound.com/index.aspx?mainMenu=view_product_simple&pid=327
2. 2x 12MB1000 (mid/bass)
http://www.eighteen.com/index.aspx?mainMenu=view_product_simple&pid=214 - http://www.eighteensound.com/index.aspx?mainMenu=view_product_simple&pid=214
# the cabinets will be used for outdoor/large scale/festival events
Any comments, tips and advice will be very helpful.
Thank you and
Kind Regards
corell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2014 at 2:52pm
You should better choose a 60° x 60° HF horn to match the dmb 12n´s dispersion.
I would not choose a 12" if i would only want it to play down to 250Hz (and they wont play lower in that horn!), but of course thats up to you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote croes89 Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2014 at 4:51pm
Thanks for the tip.
In your opinion do you prefer the mt122 or my plan?
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2014 at 5:02pm
i prefer your components but your horn is just way to short. Whats the rest of your system?
Post Options Post Options   Thanks (0) Thanks(0)   Quote croes89 Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2014 at 5:58pm
in sub I run 8x staner bp1600
http://www.staner.com.br/produtos/detalhe_produto.php?id=12&categoria=2 - http://www.staner.com.br/produtos/detalhe_produto.php?id=12&categoria=2
my amp rack contain:
1x drive rack 260
1x behringer ultra drive
1x studioR XD (run my compression drivers)
1x studioR x8 (run my midlow drivers)
http://www.studior.com.br/english/ - http://www.studior.com.br/english/
2x tasso tp2.0 (run my sub) 4 per amp (2ohm)
  http://tassoaudio.com/product.asp?id=121&depth=1&rootid=11&parentid - http://tassoaudio.com/product.asp?classid=121&depth=1&rootid=11&parentid=
Post Options Post Options   Thanks (0) Thanks(0)   Quote croes89 Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2014 at 6:04pm
but now I`m stalk on the high/lowmid tops....
if I change the 12 lowmid horn to the dvb 15n pro lowmid...do you think it going to result better?    http://www.ddshorns.com/BassMid%20DVB%2015N%20pro.pdf - http://www.ddshorns.com/BassMid%20DVB%2015N%20pro.pdf
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2014 at 6:12pm
so you have 18" Bandpass subs ?!. Your tops should be able to go down to 120Hz then. you need a 70cm horn for that...
Post Options Post Options   Thanks (0) Thanks(0)   Quote croes89 Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2014 at 7:08pm
Yes I have18" Bandpass subs. Is it 70 cm horn for the compression driver or for the low mid driver. I'm a bit confused now. If it's for the compression driver which will you recommend?
