Advice please on best way to wire these speakers? |
Post Reply | Page <12 |
Peter Jan
Young Croc Joined: 16 December 2008 Location: Belgium Status: Offline Points: 1019 |
16 Ohm connected over a bridge makes for 8 Ohm charge on each amp of that bridge, not 4 Ohm.
So total power out of that 16 Ohm bridge will be the sum of both amplifiers, roughly two times 70W @ 8 Ohm = 140W total or 70W for each sub. You can just as well connect each 8 Ohm sub to a seperate channel and get the exact same power for each sub, 70W @ 8 Ohm or 140W for both. |
Jack1991
Registered User Joined: 05 February 2020 Location: Bristol Status: Offline Points: 491 |
Ahhh yeh sorry
Cawr man thanks so much for your help and patience bet you been pulling your hair out reading my replies haha. Thanks again! 🙂👍🏼
Edited by Jack1991 - 08 April 2020 at 8:51pm |
Earplug
So my suggestion to go about, would be to use the amp in 3 ch mode. Subs
connected parallel in bridge mode on Ch A (LPF selected) and mid tops
each running of an amp channel of Ch B (HPF selected). Input selector in
2 Ch mode not 4 Ch. Feeding inputs A and B with signal ( through an RCA
Y-split cable I guess ? )." +1 Go with this. The most efficient way of using what you have. |
Jack1991
Cool yeh will do that thank you too Earplug.
Out of interest why select 2channel mode rather than 4 channel? Id of thought 2ch mode for 1 or 2 channels, and 4ch mode for 3 or 4 channels?
Edited by Jack1991 - 09 April 2020 at 6:26pm |
Peter Jan
You can choose 4 ch, but you better come up with a few more RCA Y-splits
Jack1991
Ahhh there we go. Makes sense! Why didnt i think of that! Thanks again Peter Jan! 😀👍🏼
