ADVICE & REVIEW ON POWERSOFT K20 |
Post Reply | Page 123> |
steflion
Registered User Joined: 23 March 2008 Location: France Status: Offline Points: 103 |
Posted: 19 January 2013 at 6:44am |
Greetings & Love to each & every one ,
Blessed year to each & every speakerplans members , I would like to have advice on this amp and what u think of this K20 , to drive 8 x Tmax 1500 I , 4 per side @ 2 ohms load . Is the amp will have e nough power ? is this amp deliver a real power @ 2ohms load ? ONE LOVE Edited by steflion - 19 January 2013 at 6:46am |
Music is a medecine
One love & Itection www.facebook.com/lionrootssound |
U.Viktor
Young Croc Joined: 04 May 2010 Status: Offline Points: 716 |
I would not hang all the eight speakers to a single amp for multiple reasons, I better like the sound performance of K20 with 4 Ohms loads per channel. More solid and reliable solution to get 2x K10.
Motion54
Old Croc Joined: 13 November 2010 Location: London Status: Offline Points: 1753 |
Yes 2 amps at 4ohms better than 1 @ 2ohms.
And if 1 goes down, you've still got 1 to get through the night |
levyte357-
Maybe so in the touring world. But to many, buying 20K amp to run 4x drivers, is akin to buying Porsche 911, and only using it for shopping trips. Simply not cost effective or practical. To the OP, Turbomax drivers need amplifiers with high current handling capacity, to drive them properly, as most lightweights will limit themselves when seriously pushed. IMHO, Seriously consider 2x Infinite 8 MK2s running at 4 ohm stereo. They may need certain component upgrades for long term reliability |
jacethebase
Being a Powersoft user I can tell you they perform fantastic at 2r.
I run K8's driving 4 x RCL lp200n per channel. A k20 wouldnt break a sweat driving 8 x turbomax i wouldnt have thought! What type of power supply do you have? As if you dont have a nice 32a pref 63a outlet i wouldnt even bother. |
www.stage2sound.com |
levyte357-
There is driving, and there is driving. At recent amp test, all the "so called", 3/4K per channel @ 4 ohms amplifiers, would have thermalled well before getting the Tmax 1500s out of bed. Tmax 1500s, hpf < 40hz, and lightweights often don't seem to work out. |
will_i_am
Registered User Joined: 16 March 2008 Location: Manchester Status: Offline Points: 566 |
Id say it would take 8 turbomax in its stride, however it isnt going to sound as heavy without the harmonic distortion from a heavyweight amp..
Pasi
Old Croc Joined: 25 April 2010 Location: Knutsford Status: Offline Points: 2732 |
No wonder there is problems with lightweight amp and Turbomax drivers. Re being 4.8 ohms is more like 6 ohm driver. Combine that with the low Qms and you get also lot's of losses in the suspension. So draws huge current and resists movement. 4 drivers a side ends up to Re of 1.2 ohms, under 2 ohm impedance to amp when most of the lightweight amps are rated to min 4 ohms. Surprisingly they thermal out as they are not designed to run that low loads.
Sorry. That was for 1500... The 1800 Turbomax has Re of 4.6 ohms... Edited by Pasi - 19 January 2013 at 3:07pm |
U.Viktor
Use strong 32A AC with 6mm2 cables on 230V. K20 has 7-8KW* sustained
capability power supply plus circa 1100Ws energy storage. These
electrical parameters are ideal for driving twice of large 8 Ohms
speakers per side, so even 2000W 8Ohm speakers pushed up to the maximum,
still with some small headroom left.
If you have two large drivers per side even musics with low crest factor amplified very nicely, each of the 8 Ohms drivers gets their 2KW for longer periods. However the situation on 2 Ohms is different. Low density music is OK but once the crest factor decreases the K20 collapses quickly as soon 1100Ws storage discharges pretty fast. It means that the individual 8 Ohms speaker gets 2KW only for very short some milli-seconds and power quickly drops with dense musics like sustained large amplitude low-frequency tones. Do not forget that a typical 8 Ohms driver shall exhibit 6 Ohms minimum impedance so connecting four of them you go to 1.5 Ohms. It is no problem for the K20 can handle 1 Ohm .-) but other things come up. Peak currents could top around 136A which results large losses on speaker cables and destroys damping factor. Just calculate the numbers with 1.5Ohms loading impedance vs. a standard 10m speaker cable plus connectors. Finally this is what you will hear compared to 4Ohms . *Twice of mine K20 can suck out 64A from the 230V line with nearly 1 Power factor. I have checked it for several 10seconds. So it is 7360W power input per amp. It has a same value either 4 Ohms or 2 Ohms due current limiting feature. Edited by U.Viktor - 19 January 2013 at 3:38pm |
luton_soundman
Old Croc Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4539 |
i havent used a k20 before but am skeptical about how 1 amplifier could handle 8 tmax1500i playing roots and dub with eq on the low end and preamp and not overheat when only in a 1u case?
levyte357-
The science adds up with reality.. The above is exactly what we have seen, time after time, with the Tmax 1500. 99% of amplifiers being happier driving them 1x per channel. Edited by levyte357- - 19 January 2013 at 3:55pm |
Sinai Sound
Young Croc Joined: 09 November 2009 Location: Sheffield Status: Offline Points: 631 |
I've heard an A / B test between 2 K10 and 2 Inf8 driving tmaxx
The K10 sounded cleaner and punchier, but the Inf8 had more warmth and growl Inf8 for dub/roots everytime |
