  New Posts New Posts RSS Feed - ADVICE & REVIEW ON POWERSOFT K20
jacethebase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jacethebase Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2013 at 5:46pm
A k20 wouldnt break a sweat driving 8 x turbomax i wouldnt have thought!
There is driving, and there is driving.
At recent amp test, all the "so called", 3/4K per channel @ 4 ohms amplifiers, would have thermalled well before getting the Tmax 1500s out of bed.
Tmax 1500s, hpf < 40hz, and lightweights often don't seem to work out.
Have you ever used a k series? Especially a k20 @ 9krms at 2r
Pasi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pasi Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2013 at 5:48pm
Powersoft and RMS? Being funny now, are we?
RosscoPico View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RosscoPico Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2013 at 6:23pm
Here's a couple of graphs which I found, testing the K6 & K10.
DIM100 vs Power (DIM = dynamic intermodulation distortion, see notes in PDF)
The K10 is rated by Powersoft's specs to be capable of 4kW per channel at 4 ohms.
Of course the measurement used here is slightly different, however it appears as though the K10 can do:-
3.2kW per channel at 4 ohms @ 0.1% DIM
3.7kW per channel at 4 ohms @ 1% DIM
4.5kW per channel at 4 ohms @ 3% DIM
How well does it achieve this output vs. time I hear you ask.  Here's another graph then....
So it turns out the K10 is pretty decent at 4 ohms or 8 ohms.  However at 2 ohms the power drops off rapidly after 1 second - so not all that ideal for heavy duty cycle bass lines.
Source:- http://www.diy.poweraudio.ro/albums/userpics/10001/BENCH_COMPARISON_TEST.pdf
Edited by RosscoPico - 19 January 2013 at 6:25pm
.:ELEMENT 5 SYSTEMS:.
ape3435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ape3435 Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2013 at 6:29pm
Can someone help me to understand the benefits of using 1500 watt drivers when they demand more of everything? I'm a bit baffled as I only use 800 watt drivers that works wonders. If I somehow have these 1500 watt drivers before any amp, then I would get a big a*s amp, but the only way that would happen is if I were given the drivers.... FREE. Please anyone, edify me of what I am missing.
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2013 at 6:32pm
Here are the Lev .44 scoops I designed, loaded with PD1852s, being used at Golden Palace couple of weeks ago,
Here's the Rack powering them,
Notice K10 on sub.Wink
In the same venue, at the same gig, there was also a K20, in the Motion54 rig, powering 4x PD1851 loaded scoops.
All on 32A.
So, yes, know what Powersoft K series can do, and sound like.
Like all lightweight amps, they won't sustain specified output power on a sine wave bench test, or output full specified power into subs, but at least the very best lightweights will do 2 ohm sub, with enough power for "most" of of the drivers out there, with half decent sensitivity.
Edited by levyte357- - 19 January 2013 at 6:42pm
Tweeter_Box View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tweeter_Box Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2013 at 7:09pm
K20 will be perfect driving turbomax drivers with plenty of headroom aswell Thumbs Up
SBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SBC Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2013 at 7:26pm
yep
in fact, put 8x per channel. it'll be fine.
F.T.S.S.
QSS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote QSS Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2013 at 7:34pm
There are a couple roots/dub sounds I know currently using K20 to run 8 x sub and does it with ease.
Also I've used K20 to drive 8 x PD1852 loaded minis playing heavy roots tunes at Black Roots album launch with negus melody as guest sound also playing on our set. The K20 was just cruising all night.
"Music is life"
QSS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote QSS Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2013 at 7:59pm
For all interested, come and see it for yourself at Trinity Centre in Bristol this Friday 25th Jan. Kibir La Amlak and Abashanti.
Or you can see K20 on 8 x 1852 loaded full scoops on March 30th at Tower Ball Room in Birmingham.
Edited by QSS - 19 January 2013 at 8:04pm
"Music is life"
QSS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote QSS Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2013 at 8:09pm
I don't know how they do it, but it seems to me all logics and facts in electronic science doesn't apply to Powersoft K series
"Music is life"
Gee136 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gee136 Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2013 at 9:35pm
Originally posted by steflion steflion wrote:
Greetings & Love to each & every one ,
Blessed year to each & every speakerplans members , I would like to have advice on this amp and what u think of this K20 , to drive 8 x Tmax 1500 I , 4 per side @ 2 ohms load . Is the amp will have e nough power ? is this amp deliver a real power @ 2ohms load ?
ONE LOVE
Hire/borrow/lend/rent a K20 for a weekend, play about with it on your machine, then you decide what your ears heard & what your body felt...... Thumbs Up
Respect................... Big smile
Goverment Sound (weight & treble roots machine)
When Goverment ah play, infidels, ginals & masqueraders run away.....
dylan-penguinmedia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dylan-penguinmedia Quote  Post ReplyReply Direct Link To This Post Posted: 19 January 2013 at 10:21pm
Sensible man.
I wouldn't want to spend that much money on an amp cos someone on here I'd never met before told me to.
