  New Posts New Posts RSS Feed - Advice
Advice
JOLD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JOLD Quote  Post ReplyReply Direct Link To This Post Topic: Advice
    Posted: 14 May 2021 at 12:01pm
So i'm thinking about build two cabinets, with 4 x 10" Beymas in each , i'm a novice but want to get The cleanest "pure" bass sound on a reasonable budget,
The amp driving them these will be one of MY OHM FL series and I have a DBX PA
Any thoughts
Key Features
  • High power handling (200 w AES)
  • 2\' (51.7 mm) copper voice-coil with polyimide fiber glass former
  • Optimum winding length for increased linear excursion
  • Designed for high power woofer applications
Technical Specifications
  • Nominal diameter 250 mm 10 in
  • Nominal impedance 8 ohm
  • Minimum impedance 7.2 ohm
  • Power capacity 200 W AES
  • Program power 400 W
  • Sensitivity 95 dB 1 W @ 1m @ 2Π
  • Frequency range 45-6500 Hz
  • Recommended enclosure volume 20 / 50 l 0.71 / 1.77 ft.³
  • Voice coil diameter 51.7 mm 2 in
  • BL factor 13.2 N /A
  • Moving mass 0.038 kg
  • Winding length 15 mm
  • Air gap height 7 mm
  • Xdamage pp 28 mm
Thiele Small Parameters
  • Fs 43 Hz
  • Re 6.2 ohm
  • Qms 7.88
  • Qes 0.37
  • Qts 0.35
  • Vas 65 l
  • Cms 368 µm / N
  • Rms 1.3 kg / s
  • Efficiency % 1.4
  • Sd 0.0355 m²
  • Xmax 4 mm
  • Vd 141 cm³
  • Le @1 kHz 1.7 mH
Construction Details
  • Net weight 3.5 kg 7.72 lb
  • Total weight 3.9 kg 8.6 lb
  • Magnet Ferrite
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2021 at 6:58pm
When you say bass, do you mean a PA bass cab or a bass guitar cab?
This page was generated in 1.410 seconds.
