A&H Xone 43 |
king david
Young Croc Joined: 17 January 2007 Location: italy Status: Offline Points: 1324 |
Posted: 25 November 2022 at 9:41am |
I have an Xone 43 mixer and i dont really undersrand why if you put an external effect, when you engage It, the volume of the Channel that Is effected goes down....i Just think It doesnt make sense
dj jammin
Young Croc Joined: 10 April 2010 Location: southampton Status: Offline Points: 770 |
That does seem a bit pointless.. what external effects unit are you using? Just thinking, if it's a send/return situation it should not affect volume of channel unless you are set at 100% effect and the output of the external unit is very low? Presume that's what you mean?
Reverence Sound system
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4938 |
Might it be an unbalanced>balanced problem? What does the fx unit have as i/o?
North Staffordshire |
king david
Benidub Digital delay with jack i/o
king david
From the guide Use this control to vary the amount of channel signal that is sent to an external effects device connected to the X:FX send / return on the rear panel. With this control set to ‘dry’, none of the signal is routed to the external effects loop. With the control in the central position, half of the signal is sent to external effects, while the other half is unaffected or, if filter is selected, only the dry part of signal is filtered. With the control set to fully ‘wet’, all of the signal is sent to external effects and the VCF filter is bypassed |
king david
Theres a volume drop when i move clockwise from dry to wet even with no effect linked in....
dj jammin
That would make sense as more of the signal goes from direct to the send.. possibly you might find you need to boost the output of your delay unit.. also I'm assuming the dj mixer expects stereo send and return? Guess the benidub is mono? This could be an issue as well..
kedwardsleisure
I've never heard of a benidub but googling it shows it's mono? How are you routing the stereo send & returns to it?
king david
The Xone has rca connections so i am using adaptors to the jack i/o of benidub But the Channel volume goes down when you move the FX Channel even with no FX linked in...
BigSoundNorthWest
Registered User Joined: 29 November 2014 Location: Manchester Status: Offline Points: 290 |
Noticed this too, tonight on the same model mixer at a dance. .
Was solved by raising the output on the echo pedal, but still, it's a feature of this mixer it seems, not a fault
