AH550, XT1464, ME464 Measurements |
vertx ![]() Young Croc ![]() ![]() Joined: 14 March 2012 Location: Sydney Status: Offline Points: 548 |
![]() ![]() ![]() ![]() ![]() Posted: 02 September 2022 at 10:37am |
Measured inside in a semi treated room.
Measurements gated to 400hz ish. Measurements made 30cm from horn mouth. Off axis measurements performed "by hand & eye" so take the of axis coverage patterns as a guide only, they are not accurate to the degree. Measured with an Earthworks M30 with calibration file applied, at 96khz. Measurements in REW, made from 400hz to 30khz. ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
VECTORDJ ![]() Registered User ![]() ![]() Joined: 11 June 2006 Location: United States Status: Offline Points: 489 |
A+
Keen ![]() Young Croc ![]() ![]() Joined: 30 May 2011 Location: Brisbane, Aus Status: Offline Points: 1188 |
Thanks Jackson, if you have it, would it be possible for you to post the XT1464+DCX464 measurements?
TIA
Let me reiterate a few things with these measurements - they're taken indoors, no EQ, just raw driver on horn and at that time I did not have the means to calibrate the SPL measurements as I do now.
464 on the 1464 sound like an expensive option tho. A less costly comp will get you good results on that horn. If you're a dub/root/reggae sound I'd reckon a nice 3" diaphragm comp in the 1464 is a go and if you need more 10khz+ sizzle run your bullets on top of that. ![]() ![]() |
lol, not in this lifetime
