  New Posts New Posts RSS Feed - AH550, XT1464, ME464 Measurements
vertx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vertx Quote  Post ReplyReply Direct Link To This Post Topic: AH550, XT1464, ME464 Measurements
    Posted: 02 September 2022 at 10:37am
Measured inside in a semi treated room.
Measurements gated to 400hz ish.
Measurements made 30cm from horn mouth.
Off axis measurements performed "by hand & eye" so take the of axis coverage patterns as a guide only, they are not accurate to the degree.
Measured with an Earthworks M30 with calibration file applied, at 96khz.
Measurements in REW, made from 400hz to 30khz.
VECTORDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VECTORDJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2022 at 11:09am
A+
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 1:41am
Thanks Jackson, if you have it, would it be possible for you to post the XT1464+DCX464 measurements?
TIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote vertx Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 3:11am
Let me reiterate a few things with these measurements - they're taken indoors, no EQ, just raw driver on horn and at that time I did not have the means to calibrate the SPL measurements as I do now.
464 on the 1464 sound like an expensive option tho. A less costly comp will get you good results on that horn. If you're a dub/root/reggae sound I'd reckon a nice 3" diaphragm comp in the 1464 is a go and if you need more 10khz+ sizzle run your bullets on top of that.
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2023 at 7:05am
Originally posted by vertx vertx wrote:
If you're a dub/root/reggae sound....
lol, not in this lifetime
Post Options Post Options   Thanks (0) Thanks(0)   Quote vertx Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2023 at 1:02pm
