  New Posts New Posts RSS Feed - All direct drive Turntable spindle motor need oil
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 11 December 2017 at 11:22pm
Technics SL1200/1210mk2 and others with the same motor should be oiled during routine maintenance as they use oilite (sintered bronze) bearings which dry out. If used dry they will eventually wear, causing the rocking platter symptom you sometimes find.
Any motor that uses a ball race won't require any oil there.
North Staffordshire
JAH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JAH Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2017 at 2:31am
I think you're talking about brushed motors, all the Technics use a brushless motor so no need to oil.
yes brushless motors.
So dont the SL1210 mark 2 have the brushless motor?
The higher end DJ turntables now being built all seem to have brushless motors.
Edited by JAH - 12 December 2017 at 2:33am
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2017 at 10:59am
doesn't matter whether the motor has brushes or not. It's the bearing-type that's important regarding lubrication.
Motors with brushes are rare in pro turntables, though quite common in midi-hifi style belt drive decks
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2017 at 11:37am
Correct. 35 Years ago when i was in the hifi trade,we used to sell the hi-end Technics SL models brand new, sl1400, sl1410, etc. Included in the box was allways a tiny bottle of oil to lubricate the centre bearing,one or two drops per year at the bottom of the shaft.
JAH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JAH Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2017 at 10:54pm
How does one go about finding out the bearing type of a 16-pole, 3-phase, brushless motor ? This is the motor mainly being used on the higher end Dj decks especially the hanpins.
Edited by JAH - 12 December 2017 at 10:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2017 at 11:55pm
use your eyes
North Staffordshire
Xoc1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Xoc1 Quote  Post ReplyReply Direct Link To This Post Posted: 13 December 2017 at 10:44am
The big clue is the phrase 'direct drive' -
This means that the platter is being driven directly - not with a belt or an idler wheel.
So the platter is part of the motor and there is only the one bearing.
