Allen & Heath Xone noise issue |
AM55
Old Croc Joined: 16 August 2007 Location: Matlock Status: Offline Points: 1728 |
Posted: 01 October 2019 at 10:22pm |
I have a Xone 4D and I have noticed that as the illuminated rings around the various buttons flash it causes a click in the speakers. I also notice as the 4 illuminated rings around the buttons at the bottom on each side turn on the noise floor seems to raise slightly. Obviously once music is playing it isn't a problem but it isn't ideal in my mind. Has anyone ever come across this before? Do any other of the Xone range suffer from the same problem? I'm just asking out of interest really.
cravings
check that just tapping anywhere on the case with your finger doesn't cause the same thing.. i had a 92 once that made weird noises, found a loose screw inside, so something wasn't grounded correctly. sorted all weirdness.
Cyklist
Young Croc Joined: 14 December 2007 Location: Ireland Status: Offline Points: 707 |
I have a 92 that does the same, when you have amp gains up and no signal you hear slight pops when the lfo trigger leds flicker. Never been an issue in use but must open her up and check all the mounting screws
purple monkey dishwasher
