altec lansing compression drivers & horns |
ychole audio
Young Croc Joined: 18 January 2007 Location: United States Status: Offline Points: 625 |
Posted: 02 September 2007 at 3:10pm |
Greetings to all pro audio peeps.
Does anyone of you uses altec lansing
compression drivers & horns?Any comments
on this things?Are they any good at all?
Thanks!!
I am ZERIEL'S dad!!!
jbl_man
Moderator Group Joined: 12 January 2005 Location: London. Status: Offline Points: 11154 |
yes,excellent,but they are now around 30 years old,so there are much newer and better drivers on the market nowdays,but the Altecs still have a following amongst hifi collectors....i dont think many pro-audio people use them now....just too hard to get a genuine diaphramm now if you need one.
ychole audio
Thanks jbl man,I find them very attractive!Those 511b horns are that very handsome to my eyes.Im just wondering how would they sound in the real world.
Soundwise,are they worth using?
jbl_man
err..well they are big and heavy,with a 90x40* pattern...yes they will still work...might suffer from some resonances due to the cast alloy construction....probually best to use them above 1.2khz to avoid harshness.i think the modern trend is towards smaller and lighter hf.
Peter Moller
Old Croc Joined: 26 December 2005 Location: Denmark Status: Offline Points: 2531 |
Just a general FYI: Radian offers replacement diaphragms for some of the Altec Lansing comp. driver range..
Horns etc: Forget it.. Big, heavy and some nasty resonances.. If you have some of these things, you might be able to unload them to some HIFI nutter w. a tube amp fetish, and make more than enough to get something a bit more modern..
/peter
real phone no: +45 four zero six two four four nine eight ( using obvious anti phone spam encryption )
rebelbass
Registered User Joined: 14 September 2007 Status: Offline Points: 4 |
I still have 4 288 (1.4") and 3 808 (1') compression drivers,just got diaphragms need to ab them to one that works and see how it sounds.old,heavy,ugly but they sounded pretty good (not a TAD but not 800$ to repair blown). As for the steel multicell horns...if ya gotta use them,coat the outside with car undercoating or something,if I remember correctly they "rang" if you tried to get them loud. deadening the metal helped.
opus jody
Young Croc Joined: 06 June 2006 Location: United Kingdom Status: Offline Points: 1246 |
Improvised Hardware Music http://vimeo.com/user9389813/videos
