  New Posts New Posts RSS Feed - Altered Mt122
Altered Mt122
SAMIAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SAMIAM Quote  Post ReplyReply Direct Link To This Post Topic: Altered Mt122
    Posted: 01 December 2005 at 4:42pm
If I build Mt122 rectangular and not trapezoidal and so doing increase the chamber volume but not the horn will this impact on the performance of the horn
Andrew View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2005 at 5:17pm
I've not built the 122 yet, only the 102, and in that case, a small rear chamber is best, Rog recommends an even narrower gap (hence rear chamber volume) than in the drawing, in the FAQ.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SAMIAM Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2005 at 5:43pm
I had intended to build single MT122 like Doms; his dont appear to be
trapezoidal maybe the solution is the original rear chamber (as in the plans) within a rectangular cab
Dom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dom Quote  Post ReplyReply Direct Link To This Post Posted: 04 December 2005 at 4:00pm
Mine have a rear chamber as per the plans.
