alternate driver other than void/pd |
Page 12> |
WILLIAM12345
Topic: alternate driver other than void/pdPosted: 10 July 2012 at 5:50pm |
although its normal to load 1850s with pd or void there must be a cheaper alternate driver that could be used . has anyone ever tried a different driver other than these that reach the specs needed ?
cravings
Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7507 |
Posted: 10 July 2012 at 6:22pm |
the void really is a fairly cheap driver for what you're expecting.
WILLIAM12345
Posted: 10 July 2012 at 7:20pm |
yeah but i know it is ....
but surly there is an ALTERNATIVE to the void or pd drivers £250 is still a lot of money.
imageoven
Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2199 |
Posted: 10 July 2012 at 11:08pm |
Requiem
Joined: 20 January 2011 Location: Bristol Status: Offline Points: 1808 |
Posted: 11 July 2012 at 12:09am |
You want cheap? heres cheap :
![]() Id take the void mate
www.requiem-soundsystem.com
Custom Martin Audio WSX, USB & CSG Soundsystem based in Bristol |
Dub Specialist
Joined: 30 December 2011 Location: Smethwick Status: Offline Points: 3235 |
Posted: 11 July 2012 at 12:32am |
.....free deliverly what more yu want.......![]() ![]() Edited by Dub Specialist - 11 July 2012 at 12:35am |
ceharden
Posted: 11 July 2012 at 12:58am |
The 1850 horn was designed for....... the PD1850, which is a very heavy duty driver. The Void driver is a cheaper alternative.
The bottom line is that there is no such thing as a cheap heavy duty driver, capable of handling the loading in that horn. If you can't afford a suitable driver I'm afraid you'll just have to look at a different cabinet. In general, drivers capable of withstanding horn loading are more expensive. |
levyte357
Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Posted: 11 July 2012 at 1:19am |
![]() Cheaper alternative, would be used PD1850s, V18-1000s. For 186 Horn, "maybe" worth considering used Turbomax 1000/Fane 18-1000. |
Dub Specialist
Thanks(1)
Posted: 11 July 2012 at 1:21am |
maybe a Fane 18b ? strong cone/good driver suitable for horn loading and fairly cheap you can pick them up.......
Keen
Joined: 30 May 2011 Location: Brisbane, Aus Status: Offline Points: 1271 |
Posted: 11 July 2012 at 9:51am |
yeah was thinking the fane 18b600/800. Recomended driver for the Invader Horn by Nineleaves. But won't do 30hz in the bigger stacks reliably. For this Nineleaves recommended stepping up to PD1850 or Fane 1000/1500 (in invader). But 40hz fine for 18b. 18b600/800 has the high EBP of the 1850. This is what your looking for if your trying to reproduce sound of the 1850. Fane 1000/1500 both lower EBP so more hifi sound.
levyte357
Posted: 11 July 2012 at 10:12am |
However 18B, just doesn't have the Xmax or BL to handle high power input whilst staying in control.
ClackS02
Joined: 12 March 2013 Location: United Kingdom Status: Offline Points: 33 |
Posted: 19 March 2013 at 2:08pm |
if you want cheap, i wouldnt expect much out of it :/ unless your a wizard with enclosure design :P
Page 12> |
