  New Posts New Posts RSS Feed - Alternative driver for Turbo 10" horn
LunchieTey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LunchieTey Quote  Post ReplyReply Direct Link To This Post Topic: Alternative driver for Turbo 10" horn
    Posted: 07 May 2018 at 12:56am
Anyone know a suitable driver for TMS3 mid horns? I have 4 working LS1001 drivers but seeing as they are basically impossible for me to recone in Australia if they fail, is there a reasonable replacement around? I should also mention the horns are not in a TMS3 cabinet anymore and only need to go up to 1.2k.
Am open to slight mods of the phase plug of necessary.
Have even considered removing dust caps on 10s and replacing with an inverted cap.
Impedance is not an issue(dont have to be 16 ohm) and being able to run them down a little lower would be nice too.
They are going to be used in a 3 way box with dual slot loaded midbass( possibly a ppsl alignment and a decent comp above(undecided) will be controlled via ultradrive and driven by qsc gx5.
Thanks
Edited by LunchieTey - 07 May 2018 at 1:47am
Speaker addict
This page was generated in 0.079 seconds.
