Alternative driver for X-tro...? |
Page <1234> |
| Author | ||
mobiele eenheid
Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1563 |
Posted: 30 November 2005 at 2:48pm |
A sub almost always radiates in 2 pi, but a top radiates more likely in 4 pi. The lowsection of the Xtro consists of 2 BPH. So the simulation of a single BPH in 2 pi will be close to the actual performance of the Xtro's lowsection. |
Mircea Bartic
Joined: 18 February 2005 Location: Romania Status: Offline Points: 2589 |
Posted: 30 November 2005 at 3:31pm |
the thing is that I consider that a sub should still couple with the
ground within 1 wavelenght of the frequency band, so I modeled the
x-tro in 1 pi because even at 200Hz the top is still close enough to
the ground to benefit from half space conditions
1pi= 2 midbass horns in halfspace= 1 x-tro positioned above 2 punishers I maybe wrong , but tests until now seem to confirm my teory |
PoteirosCorp
Posted: 30 November 2005 at 9:54pm |
mobiele eenheid
Posted: 01 December 2005 at 8:05am |
What tests?
At 2,83V/1mtr but how about at full power? |
Mircea Bartic
Posted: 01 December 2005 at 1:21pm |
tests made with a horn loaded cabinet (not xtro)
mobiele eenheid
Posted: 01 December 2005 at 3:14pm |
I mean; What did those test involve (what was the setup, conditions, etc.) that you can say they confirm your theory? |
Mircea Bartic
Posted: 01 December 2005 at 4:03pm |
there was a hd15 type bass suspended in air
I ve discovered that you don't have to put the sub right on the ground to gain the extra dB (I did not have a measurement system at that time so No actual numbers.) I did the test after I saw that many of the sound companies lift their subs on tables during the concert ![]() |
Rengade Project
Joined: 12 December 2004 Location: United States Status: Offline Points: 601 |
Posted: 01 December 2005 at 11:30pm |
Do any of the McCauley 15" have suitable parameters for the famed Xtro.
MUSIC SWEET,www.myspace.com/renegadeproject
Mark James
Joined: 15 January 2006 Location: rig side Status: Offline Points: 5306 |
Posted: 26 February 2006 at 4:09pm |
whats the prices individualy then? Edited by coner - 26 February 2006 at 8:37pm |
Jay Lawless
Joined: 22 August 2005 Location: United States Status: Offline Points: 1702 |
Posted: 26 February 2006 at 5:07pm |
@Nexus
i've only used hornresp to try out some bass horn ideas, how do you compare two designs like that? |
Background: Automotive, Live and Home Custom Design. mid/high level based design and feild experience. Bass specialist |
Mike Severloh
Posted: 27 April 2006 at 9:38am |
Hi all ! For a couple of years now my drumfills (drum monitor loudspeakers) are 15inch mids from 100-1000Hz. So I recon the speakers tested suite the xtro, too. Good results were achieved by using the old RCF L15P801 in Monacor/Harmonic Design horns 22x22x15", the older JBL 2220H and the very old JBL2220A, in PublicAudio- horns sized 17x17x11".
Next will be B&C 15PLB76 (short excursion, ferrite), and 15NDL76, in the larger horns. The short ones will stay horn monitors for good, but AJHorn 5 suggests the JBL speakers near perfect in the larger ones as well. I also consider B&C 15NW76, BMS 15S420, 15P200, 15N620 and 15N820 very interesting for this low/midrange use. The SAMMI SR15A380 should be fine, too. Maybe someone expirienced the Bxx in horns like the xtro already, pls let us know. @Rengade Project: I did not have the chance to test McCauley 15" yet.
Cheers.
Mike Severloh. |
Mike Severloh
Posted: 27 April 2006 at 9:47am |
Hi again, I forgot the BMS 15S320, the older Solton CRAAFT 15XR600 (very lightweight moving parts), and the ancient workhorses JBL D130, and RCF L17P/64 AF(used successfully live in the PublicAudio horns).
Mike. |
Page <1234> |
