  New Posts New Posts RSS Feed - alternative drivers for MTH30
jamwa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jamwa Quote  Post ReplyReply Direct Link To This Post Topic: alternative drivers for MTH30
    Posted: 25 March 2011 at 7:13pm
Hey Chaps
just looking at the Faital website - how would the 12" 12hp1020 driver work in a tapped horn style box
slightly better Xmax than the PD12sb30 and maxW
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2011 at 2:02am
It looks like both drivers are displacement limited, so the higher power rating is not a big deal.
The difference in displacement works out to a 1.38dB SPL difference (in favor of the Faital Pro).
Edited by _djk_ - 26 March 2011 at 2:03am
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote jamwa Quote  Post ReplyReply Direct Link To This Post Posted: 05 April 2011 at 5:37pm
okay thanks djk.
has anyone compared the MTH-30 with the tapped horn that matinsson has developed and marjan has adapted..
mikey bear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikey bear Quote  Post ReplyReply Direct Link To This Post Posted: 06 April 2011 at 12:47am
I have compared the MTH with the Martinsson. Although not with the suggested B&C 15TBX100 but with a PD1550. There's not much in it (as the sims suggest) and i couldnt really tell much difference. To get the most from the THAM15 you need the B&C or the BMS equivalent. Funnily enough, the 12sb30 goes pretty low in the THAM according to sims (on par with the b&c), although displacement seems to be high.  I guess thats the trade off?
This page was generated in 3.922 seconds.
