  New Posts New Posts RSS Feed - Alternative to sn12b for porn horn v1
double fred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote double fred Quote  Post ReplyReply Direct Link To This Post Topic: Alternative to sn12b for porn horn v1
    Posted: 06 January 2013 at 12:10pm
Hello,
I own 4 porn horn v1, and 1 of the p.audio sn12b driver has stopped working Cry
Is there any hope for a replacement solution, since the horns have phase plugs to fit the sn12b and I still got 3 working fine ?
Else if anyone knows of a good condition second hand sn12b, and willing to ship to france, please let me know !
Peter Jan View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Peter Jan Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2013 at 1:53pm
Can't it be reconed ?
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2013 at 1:59pm
they sell replaceable baskets for these... blue aran are the uk distributers, or mircea seems to have good contacts with them, so he might know about availability..
Post Options Post Options   Thanks (0) Thanks(0)   Quote double fred Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2013 at 4:44pm
Thanks !
I don't know what's wrong with it. Last they were fine at packing time. I've always used them with "dj proof" limiters and adequate power.
The cone is fine and slightly moving if I push it by hand, however nothing moves when fed an audio signal.
I suspect it's to do with rust, the cabs were kept in a very wet place, and the screws on the driver are all rusty. Which make for another problem : I can't open the driver, unless I cut clean off some screw heads.
Edited by double fred - 06 January 2013 at 4:49pm
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2013 at 11:48am
unfortunately I can't get any SN12B....
They're discontinuedDisapprove
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2013 at 4:10pm
BMS 12S310
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter Jan Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2013 at 6:32pm
BMS 12S310
If recone kits or repair assemblies aren't available anymore, the above plus :
B&C 12PE32
Beyma 12MI100
P. Devices PDN12MH25
RCF 12P110K
Eminence Kappa 12A
Ciare NDH 12-3
18Sound 12MB600/700/1000 + 12NDA520
Post Options Post Options   Thanks (0) Thanks(0)   Quote double fred Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2013 at 8:54am
Thank you all !
BMS 12S310
This looks like the way to go.
3" voice coil, similar power for same output, and T/S parameters are pretty close.
Good price range and availability too.
Shame it's not neo ! Least it'll be easy to remember which cab has the new driver fitted, the heavy one !
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 20 January 2013 at 3:53pm
still got 2x sn12mb 200W version if your interested..
Post Options Post Options   Thanks (0) Thanks(0)   Quote double fred Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2013 at 6:49pm
Hi,
If they are sn12b, I'm very interested.
If they are sn12mb, I'm not.
Let me know 100% please, thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2013 at 7:07pm
12mb sorry..
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2013 at 7:52pm
My mate has 2x SN12B, but would probably want £220 for the pair.
This page was generated in 0.059 seconds.
