Amcron MacroTechs |
vinro ![]() New Member ![]() Joined: 29 May 2022 Location: cambridge uk Status: Offline Points: 3 |
![]() ![]() ![]() ![]() ![]() Posted: 05 June 2022 at 9:09pm |
Question regarding Amcron MacroTech amps.
Colleague wants to mic, amp and sub his bass drum.. He has one HZ SB600 as a sub..also mics (Shure and AKG D112) I was going to lend him one of my old Bose 1800's (series ones) but looking at the SB600 the two coil inputs if both used present 4ohms.. and the old Bose, when bridged, must see 8 ohms.. So.. looking at Crown user sheets it would appear that the MacroTechs (601,1201 and 2401) can, when bridged, drive into 4 ohm with no problems.. So, question one ..is this correct ? (when bridged they can drive into 4 ohms all evening ?) Does any have any more info on the HZ SB600 ? (reaching out to djeddie here as, looking through older posts, he seems to know a fair bit about them.. And, lastly, does anyone know of a nice MacroTech anywhere ? Not so keen on e-bay..colleague missed two.. but I suggested he holds off impulse purchases until I find out about bridge mode into 4 ohms.. Why Crown/Amcron..I used them back in the day and they never gave out or caused problems (mind these were the much older DC150's) so just have a soft spot for them..happy to be advised otherwise.. all best Nick |
Elliot Thompson ![]() Old Croc ![]() ![]() Joined: 02 April 2004 Location: United States Status: Offline Points: 4981 |
Yes. The Crown Macro-tech (and the Micro-tech) can drive 4 ohms Bridged Mono all day with no issues providing you feed them enough current. They can also drive 1 ohm loads, Parallel-Mono configured.
Best Regards,
knet94 ![]() Young Croc ![]() ![]() Joined: 31 March 2008 Location: NW London Status: Offline Points: 1453 |
I've got a MA1202 and a MA2400 that I'm looking to move on.
knet94 as I am but an egg crocwise it appears I cannot PM ? How can I contact ? I did think my e-mail was in my profile .. best nick
I've sent you an e-mail. I didn't even know that feature I used existed. However if that didn't work you can get me on o7557 o9o225.
BJtheDJ ![]() Young Croc ![]() ![]() Joined: 28 November 2012 Location: Bristol Status: Offline Points: 836 |
You need to have accumulated at least 10 poiunts before you can send PMs or post pictures, in fact most things except read and reply
If your vaccinations were mandatory and nobody in your class had measles,
then you know that you're not a Millenial kid.</f |
