American Audio V6001 Plus ??? |
Page <1 2345> |
| Author | |||||||||||||||||||||||||||||||||||||||||
luton_soundman
Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4550 |
Posted: 14 May 2012 at 12:43pm |
i'd go to that ![]() |
levyte357
Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Posted: 14 May 2012 at 3:17pm |
OK. These specs I saw on another website were misleading then, as they state, http://www.directproaudio.com/product.cfm?directid=57377
To be honest, I'm not interested in 1khz measurements for a sub amp, as I don't need 2kwpc @ 4 ohms of 1khz, thru my subs. One source of assurance, is when the manufacturer is confident enough to state the 20-20khz performance of an amp.
If the V6001plus has same number and type of O/P transistors as Inf8MK2, 1. Why is the V6001 1khz o/p power at 4 ohm, "much" less than the Inf8Mk2 4 ohm O/P figure measured at 40hz ? http://www.abeltronics.co.uk/amptesting.php?z=Void_Infinite_8_mk2
Lewis mentioned 2 ohm stereo sine testing at 40hz resulted in premature clipping, which limited output. 2. Why is the Damping factor of V6001 at 8 ohms, less than the damping factor of the Infinite 8 MK2?
I don't know anyone who with £3K to buy a sub amp, who would buy a new CA18 for £2899. They would most likely buy a used K10 for approx £2K, or 2x PL380 for approx £3K.
Now the £650 price tag, and 5 year warranty are major selling points. Instead of comparing this amp to an Infinite 8MK2, would be better comparing it to budget 5K torroidials.
I have owned an Infinite 8MK2, but don't sell them and wouldn't be buying another one. However for many other people, the amp has proven itself, being used in gigs, or on bench 40-50hz, as the ultimate 4 ohm stereo torroidial amp for sub. So cannot be compared to the budget layer of 5K'ish torroidials. As you've said the, 6001plus has it's place in the market, agreed. As no one has measured the output yet at 4 ohms 40-50hz, and the manufacturer hasn't published 20-20khz figures, and I've seen no feedback regarding amp driving 2x heavy duty 5" VC drivers like PD1850 or Turbomax 1500 per channel, I'm just saying the pic of the amp internals raised few questions in my mind. So all will be revealed if we can line up 4 ohm stereo test, against 5000VZ, CA18, Naphon, Audiocenter 12.2 & Darq PA18, QSC 5050, Phonic XP5000, Crown XLS5000, in building with solid supply. Edited by levyte357 - 14 May 2012 at 5:15pm |
darkraver
Joined: 29 September 2009 Status: Offline Points: 143 |
Posted: 14 May 2012 at 4:51pm |
Well any test / comparison will be fun for sure.
As said my USD360 China (3 stepp Class H, 3rd step = 180V) amp beated the V6001, Ram Bux (something), EV TG7, Yorkville AP6040, Chevin A6000 (yes, indeed) and so on pure on raw power output. Basically the V6001 is something like a pimped down (3th step = 150V ??) version of my China cracker ! Edited by darkraver - 14 May 2012 at 6:08pm |
RosscoPico
Joined: 31 January 2007 Location: Brighton, UK Status: Offline Points: 955 |
Posted: 17 May 2012 at 7:59pm |
The specs aren't misleading, those wattage figures are for 1% THD so they are obviously going to be higher figures than outputs measured @ 0.1% THD.
I agree with you there, it is frustrating that AA and some other brands don't give 20-20KHz figures so I totally see your point in this respect.
Neither do I, especially for the full retail price! I brought up the cost factor, as I know that any potential buyer would surely expect that an amplifier that has a vastly more expensive retail price than another comparable amp with similar specifications would be getting something at least for all this extra outlay... Of course this will be brand reputation, warranty period, servicing, reliability, quality of components etc. The point I was trying to make is that I'd expect the V-6001 must be inferior in some regards, considering that the retail price for it is around 30% of the CA18. Even if the V-6001 is only 4000w rather than 5000w on bass then I think it still represents very good value for money as there are UK suppliers and they are well built and reliable. Having said that, I'm sure you can find other Chinese made amps which can do the same or better and it would be interesting to have a shoot out one day!
American Audio has a 1yr warranty in the UK and 3yrs in the US. It was Crest that I was referring to for the 5 year warranty.
That's good then and I think we have a better understanding now - I'm all for putting things up for test as that's the real way to find out the winners and losers in the game! That's also why I respect Mr Abel for the work which he has done in this regard, and so I say - bring on the next amp meet I really don't like manufacturers which make false claims about their products, so ultimately I'm all in favour of ascertaining who tells the truth and who fabricates the lies!
It looks like doing more testing will be the only way to find the answers so I hope that it will happen and we'll get to the bottom of it all... I had a look at the Ram Bux amps, they do look interesting eh ![]() If this test materialises, I can also also bring along a high power lightweight (e.g. 7kW Matrix) to see how this compares to the torroidials as I think this would be interesting too!
Edited by RosscoPico - 17 May 2012 at 8:10pm |
.:ELEMENT 5 SYSTEMS:.
luton_soundman
Posted: 17 May 2012 at 8:09pm |
amp test it is then. lightweights and torroidal. can bring a few heavy weights down
ermita
Joined: 19 August 2010 Location: Surrey, TW10 Status: Offline Points: 1266 |
Posted: 17 May 2012 at 8:31pm |
When
RosscoPico
Posted: 30 May 2012 at 2:19pm |
Hi Tekasis, I've got a couple more used ones available now, so drop me a PM if your friend is still interested |
elkeithos
Posted: 05 January 2013 at 6:15pm |
greetings i see that you all are discussing v6001 I just wanted to know if anyone has or know were I can find a schematic or service manual for the v6001 plus?
RosscoPico
Posted: 05 January 2013 at 6:19pm |
Hi Elkeithos, I'm afraid I don't have a service manual, so I'd suggest dropping an email directly to their service dept here:- service@adjgroup.eu |
satta sound
Joined: 24 November 2010 Location: The Netherlands Status: Offline Points: 100 |
Posted: 11 February 2015 at 9:36pm |
anyone can tell me some more about this amp performing 4 ohms a side on sub duty after two years of no posts in this thread?
I can get these for cheap. |
elkeithos
Posted: 12 February 2015 at 12:23pm |
They work like a charm I got 4 of them and I run them at 4ohms no problem they just need a little servicing once in a while just like any other amp....... Edited by elkeithos - 12 February 2015 at 12:25pm |
taurusty
Joined: 09 January 2007 Location: Jamaica Status: Offline Points: 504 |
Posted: 12 February 2015 at 4:07pm |
+1 and internal components easily sourced (here in Ja.)
Page <1 2345> |
