Amp for 2ohm |
Post Reply | Page <12 |
Hemisphere
Funktion One use rebadged MC2 amps, so that would be the obvious choice. Not sure which models they use exactly but if you compare the specs you can work it out.
tthorsten
Registered User Joined: 22 April 2004 Location: Germany Status: Offline Points: 134 |
for 2ohm buy Hoellstern www.hoellstern.com the ony choice for Basscontrol, and gerat Audiosound - no other amp on this planet will compete or even hold up on the same level and its not that expensive you would expect.
www.tb-audio.de LEVELchek www.levelcheck.de SPL tracking SATlive www.satlive.audio best Measurementsoftware for Live People DBlimits www.dblimits.com Isemcon EMX7510 measurment Microphon |
JonB67
*grabs popcorn and a comfy front row seat
No other amp on this planet? Really? Can you back that claim up? |
boots-hifi
Old Croc Joined: 15 August 2011 Status: Offline Points: 2460 |
Just get 3 Crest 8001, job done.
mini-mad
...well, the marketing department has a lot to answer for! 1.6ohm load capable(???) Has anyone even HEARD of these amps? Going sinse 2004 and all made in Germany to the highest spec. No corners cut(??!!!!) ...just from the write up I wouldn't mind a demo... |
Earplug
"all made in Germany" Unfortunately, not everything made in Germany is that good. The 2 worst vans I ever owned were Mercs... |
mini-mad
I ment as in made on sight and not out sourced... wasn't suggesting being made in Germany is the reason it good. |
70,s hero
Young Croc Joined: 14 December 2014 Location: bristol Status: Offline Points: 637 |
+1 I install/service boilers, the new vaillants pure range are ok but I have had some major issues, one took 5 visits to sort out and it was only a year old, I emailed them as the fault was dangerous in the extreme....no reply
Top banana
Father-Francis
Old Croc Joined: 24 October 2007 Location: Kenya ,Denmark Status: Offline Points: 2760 |
sprichst du deutsch, es wird helfen |
