Amp for X1's |
roundsoundz
New Member Joined: 07 March 2008 Location: Norfolk Status: Offline Points: 6 |
Posted: 14 July 2009 at 5:30pm |
Hi all, i plan on building 4 X1's and loading them with the PAudio SD18's, what do you use to power yours, i was thinking Crown XLS 5000 to power all 4, 2 per side? what is your opinion of this amp, do you think it will be up to the job? or is it better to get two t.amp pro 3000 and run them @ 8ohm with one X1 a side?
breakdabeat pete
Young Croc Joined: 10 March 2008 Location: norwich Status: Offline Points: 758 |
crown xls are crap
i wouldnt wana put much more than 800w into the sd18 due to its lowish xmax 800 each will do check out matrix xp3000,proline 3000 Edited by breakdabeat pete - 14 July 2009 at 9:16pm |
٩(̾●̮̮̃̾•̃̾)۶
jonminns
Old Croc Joined: 13 April 2008 Location: United Kingdom Status: Offline Points: 1877 |
sd18 = rubbish
xls5000 = rubbish a pair loaded with v18-1000s/pd1850 would move more air than 4 sd18 matrix xp5000 + void v18-1k/pd1850 |
breakdabeat pete
I wouldnt call the sd18 rubbish
theres just better drivers that are cheaper |
٩(̾●̮̮̃̾•̃̾)۶
jonminns
side by side with a v18-1000, at the same price, i'd call it pretty rubbish
