  New Posts New Posts RSS Feed - Amp Internals 2
Amp Internals 2
 Post Reply Post Reply Page  <1 220221222223224 260>
michel29 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michel29 Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2018 at 10:05pm
Originally posted by odc04r odc04r wrote:
Ah well, you can always re-use the transformer and build something better in the enclosure when they die. Looks oversized for the output.
transformer ?
i prefer re-use transformers from mini-HiFi components
better construction
better primary/secondary insulation
not toroïd > better mains'noise attenuation
i've fixed a Cambrige amplifier with a transformer from a Philips Mini HiFi system
on Cambride , the worst toroïd , made in china by childrens ?
il was dead , short-circuit in primary
on Philis a good Tam-radio E-I transformer  fitted with good magnetic shield
Edited by michel29 - 18 September 2018 at 10:14pm
Jakeeboy64 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jakeeboy64 Quote  Post ReplyReply Direct Link To This Post Posted: 13 November 2018 at 11:37pm
Don't suppose anyone has a circuit diagram for the PSL 2401? I have 2 of them and 3 out of 4 channels have a little too much DC offset. Thanks
Edited by Jakeeboy64 - 13 November 2018 at 11:43pm
user91 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote user91 Quote  Post ReplyReply Direct Link To This Post Posted: 23 January 2019 at 8:33pm
Irni L FPX 3000 /  Made in Bulgaria
2 х 2100W / 2 ohms, 2 х 1500W / 4 ohms, 2 х 900W / 8 ohms
Uniqaudio PA 1800 / Made in Bulgaria
2 х 900W / 2 ohms, 2 х 800W / 4 ohms, 2 х 450W / 8 ohms
Edited by user91 - 23 January 2019 at 9:30pm
Tonskulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2019 at 6:07am
Bose entero 4400
4 x 400W/8ohm
2 x 900W/8ohm (I measured 2 x 903Watts rms @ 40Hz).  I don't recommend 4ohm bridge load, this amp is happy with 4 x 4ohm or 2 x 8ohm.
Very sweet sounding and flawless amp. Almost silent at idle, no fan noise at all and they are responding really fast for increasing or decreasing loads. This amp really does what they claim in product manual.
4AC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4AC Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2019 at 10:27am
I think this Bose Entero is a rebadged version of the Bittner 4X DUAL Series, maybe slightly modified:
I had two Entero 4400's once, both with failures. My repair guy said that they were beyond economical repair. Not that this says anything about the reliability of these amps...
Edited by 4AC - 28 January 2019 at 10:28am
uǝɿɿɐʌǝ6ɯo sı ʇsʞǝʇ ǝzǝp
stanley dj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stanley dj Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2019 at 10:52am
it is bittner is making amps for more brands
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2019 at 7:22pm
Originally posted by michel29 michel29 wrote:
the worst of worst
Ibiza Amp300
it works
bench test : 2x 45w RMS /8 ohm
2 channels driven
sold as 2x 160w / 8ohm
I'm suprised they even bothered with descrete components in this,a chip-amp would have produced 2x45w no problem.
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 06 February 2019 at 7:03pm
You COULD of had a pair of clone 405 amps in there for a minimum of DOUBLE the output...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2019 at 8:54am
Carlsbro powerline pro 2000
Compared to Tamp TA1400,  look at the difference.  Output power? Measured almost the same!  Carlsbro has rail voltage of 2x110V (class ab), Tamp 2x115V (class-h, upper voltge).
Had to repair one of these (got 3 for a good price!).  Solder joint failure.
There seems to be many chinese amps having the same guts..  Pretty good amp tho, just not quite as powerful as they claim.  Soft start circuit (I wish the relay never fails to disconnect!), good clipping behaviour, nice sound quality..
I measured 1300-1400W/8ohm bridged, RMS sine wave @ 40Hz, mains voltage dropped from 230 to 220V which indeed makes things worse.  Tried to measure 4ohm bridged, but it blew the 16A mains fuse.
Edited by Tonskulus - 22 March 2019 at 9:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2019 at 9:31am
Mosfet amplifier module from ACS active 2x18 subwoofer.  Two amps in bridge configuration (16 fets total, 2SJ56 / SK176 pairs).  Going to put this thing to a 3U rack enclosure to be used as stereo or bridge mode, very good sounding amp it is! Measured around 1kW rms / 8ohm. Rail voltage +/-95Volts, needs bigger tranny (higher VA rating). Propably more capacitance for filtering, there is 2x10000µF.
One of the driver pcb:
Edited by Tonskulus - 22 March 2019 at 9:37am
Group2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Group2 Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2019 at 12:27pm
Are you still crown xti expert:)? I have some problems with this model. Maybe you will help..
larslars805@gmal.com
Chris Grimshaw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Grimshaw Quote  Post ReplyReply Direct Link To This Post Posted: 14 April 2019 at 1:52pm
Anyone interested in seeing a Crown MA12000i?
Got one here I don't mind opening up.
Chris
Quality sound from Sheffield
www.grimshawaudio.com
This page was generated in 0.234 seconds.
