Amp Internals 2 |
Post Reply | Page <1 223224225226227 260> |
odc04r
Whatever it is care during assembly does not seem to be the best for through hole components
M4trix
Registered User Joined: 23 June 2009 Location: Croatia Status: Offline Points: 445 |
That's one of RAM Audio model ?
gen0me
JJax
Registered User Joined: 10 April 2015 Location: Estonia Status: Offline Points: 17 |
Amp form one of my Beag HEC90 studio monitors. Made in Hungary in 1986. Tri-amp, 4-way. 15" + 8" + high-mid horn + supertweeter. 3 amp channels + "processing" board. Two power supplies - the brown potted transformer powers midrange and tweeters and the toroid powers the woofer. 80+kg per monitor.
When life gives you lemons, sell them and use the money to buy more audio gear.
DjLeco
Young Croc Joined: 21 April 2009 Location: Bucharest Status: Offline Points: 817 |
Great price, great amplifier! Put'em to make money!
kedwardsleisure
QSC K12 amp module
North Staffordshire |
M4trix
What's that Kevin ? A door bell ?
kedwardsleisure
can't grumble at the sound it makes, and everything's glued down very firmly.
Hopefully, by the end of the year, I should have 20 of them at my disposal. Best Regards, |
U.Viktor
Young Croc Joined: 04 May 2010 Status: Offline Points: 716 |
Cheapish (made in China) and very low performance amplifiers found in 99.9% of the ACTIVE SPEAKER products today! A very bad & ugly trajectory.. Oh I forget to say that the *errors of sound system* are usually ?! eliminated--corrected ?! by DSP .. :-(((((
Edited by U.Viktor - 16 July 2019 at 2:03pm |
Tonskulus
Registered User Joined: 15 September 2017 Location: Finland Status: Offline Points: 425 |
Thats the way it is. Marketing and manipulation sells better than real quality. *Modern dsp controlled = to make horrible raw response look more flat *light weight smps power supply = under powered *Rigid cast frame woofer = other parts taken from the cheapest model available including miniature magnet *computer modeled horn = how to make it as cheap as possible and to have some kind of directivity For typical customer, these and many other marketing terms looks good. So they buy them. And most people listening music in concerts will not blame the SQ. Everything works as planned, no need to make any changes and money is circulating. |
al_x
Young Croc Joined: 12 February 2006 Status: Offline Points: 834 |
I picked up this Alto Mistral 6000 for cheap. 3u 27kg 2 x 770w rms @ 8ohm 2 x 1170w rms @ 4ohm 2300w @ 8ohm bridged Edited by al_x - 18 July 2019 at 12:22pm |
