  New Posts New Posts RSS Feed - Amp Internals 2
Amp Internals 2
 Post Reply Post Reply Page  <1 224225226227228 260>
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2019 at 8:33am
Here's a Crown MA12000i that I had the opportunity to repair this week, pics are a bit blurry but I was having trouble containing my glee...
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2019 at 5:46pm
Did you have the chance to bench test the amplifier?
Best Regards,
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2019 at 11:19pm
not exactly, I shoved it on the dummy load and got it nice and warm, you know, the mode where it sounds like a vacuum cleaner.
https://youtu.be/D40i8F6f9ls
On a pure sine wave input the limiter tends to pump as it approaches max output, I doubt this is likely in normal use.
Edited by kedwardsleisure - 19 July 2019 at 11:24pm
North Staffordshire
Pinyorouk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pinyorouk Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2019 at 11:56pm
Ken, you have no fear of things going bang 😃😃.
Edited by Pinyorouk - 20 July 2019 at 7:25am
M4trix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M4trix Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2019 at 12:00am
You're using a good old analog oscilloscope. Good. Not those digital rubbish. Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2019 at 12:33am
Thanks. That video answers more questions than you might imagine.
One of the things I've noticed about the second generation of Crown's Class I series is, greater stability under long-term conditions than, their first generation models. Your results of the Macro-Tech I 12000 are similar to DJ Leco benching the Macro-tech I 5000 in addition to the CTS 3000 from a longevity standpoint. The second generation I-Tech Series does not go into cardiac arrest like the first generation I-Tech Series.
This may be the reason why Crown literally abandoned the first generation I-Techs in terms of sending them back to their factory in order to have them repaired. Crown no longer offer parts for the first generation I-Techs, which led to a lot of used first generation I-Techs for sale on Ebay.
Best Regards,
paulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulus Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2019 at 12:18pm
old crest fa2401 gave it a clean out the weekend , super build quality !!
Edited by paulus - 23 July 2019 at 12:19pm
TRENDSETTER SOUND SYSTEM
U.Viktor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote U.Viktor Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2019 at 1:09pm
Not only the 1st gen. is problematic from the I-techs. Despite the theoretically good and quality designed circuitry the actual realization of the amp has built-in disasters such as "critical function nodes" of the gate-driver boards across unreliable connectors.. When we went to Romania roads couple hundreds of kilometers, many of these amps has refused to work // starting uo, creating not a small problem for on site. :-(
Another problem is the too many ribbon cables and power supply sensitivity of overloading conditions.
Tonskulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tonskulus Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2019 at 9:40pm
From Crown website (MA12000i):
"Rugged construction ensures that all Macro-Techs are built to withstand years of abuse on the road"
Oh well.. :D
Meat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meat Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2019 at 9:57pm
Designed for life on the road without corners.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 23 July 2019 at 10:49pm
this one's been toured for some years
North Staffordshire
Chris Grimshaw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Grimshaw Quote  Post ReplyReply Direct Link To This Post Posted: 24 July 2019 at 8:40am
What sort of output voltages were you getting, and what was the load connected?
TIA,
Chris
Quality sound from Sheffield
www.grimshawaudio.com
This page was generated in 0.262 seconds.
