  New Posts New Posts RSS Feed - Amp Internals 2
Amp Internals 2
 Post Reply Post Reply Page  <1 232233234235>
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2020 at 10:23am
Potted with something very hard, they must've learned it from powersoft. All in the airflow so got to be for protection from dust and moisture.
Either way the thing's scrap!
North Staffordshire
JJax View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JJax Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2020 at 7:54am
Tasso TD-8000
Class TD. Power amps look to be Lab.Gruppen copies.
Manufacturer claims:
2x 1300W @ 8ohm
2x 2300W @ 4ohm
2x 3200W @ 2ohm
3900W @ 8 ohm bridge
4900W @ 4 ohm bridge
ACM M2500
When life gives you lemons, sell them and use the money to buy more audio gear.
M4trix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M4trix Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2020 at 11:42pm
Speaking of which, is any European country making these special heat sinks for amplifiers ?
Or does someone here have these lying around and wants to get rid of them ? Of course,
bare heat sinks without the PCB and stuff.  Smile
Edit: Preferable 3U height
Edited by M4trix - 02 July 2020 at 10:00pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2020 at 9:42am
I have plenty of heatsinks lying around, a couple - or more - similar to what you have posted. How many do you need?   Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote M4trix Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2020 at 1:40pm
@Earplug, check your inbox. Smile
Edited by M4trix - 02 July 2020 at 2:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2020 at 4:13pm
Ok, on to it!  Smile
mgee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgee Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2020 at 9:26pm
Please assist with some
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2020 at 10:39am
Citronic MA1300 with a MacGregor inside
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2020 at 1:10pm
Nice and simple inside.not much to go wrong. What's the line of splodge running down the centre of the heatsink,or is it two separate heatsinks meeting at that point?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2020 at 7:29pm
Quote not much to go wrong
This will be the 5th one (out of 5) that have been BER.
The last 4 had caught fire and this one has all the mosfets blown and the bus capacitors open circuit.
The two heatsinks have a bead of silicone down the middle to seal them for the fan
North Staffordshire
APW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote APW Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2020 at 7:50pm
Quality item then!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote M4trix Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2020 at 1:14am
Citronic you say...hmm... do their amplifiers have a bunch of those silly ZTX transistors ? LOL Wink
This page was generated in 0.234 seconds.
