  New Posts New Posts RSS Feed - Amp Internals 2
Amp Internals 2
 Post Reply Post Reply Page  <1 238239240241242 260>
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 07 February 2022 at 9:13pm
Originally posted by kedwardsleisure kedwardsleisure wrote:
It's impressive, right down to the need for a 32A supply.
Wow. Just wow.
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 07 February 2022 at 10:38pm
I'm just impressed they managed to get that much solder onto that 'fuse' without completely melting the whole plug!
As for the amp, it looks like the mechanical guys have done their job, well apart from making the case too big!
Robbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbo Quote  Post ReplyReply Direct Link To This Post Posted: 07 February 2022 at 11:29pm
Maybe too many people are watching the TV programme "The Repair Shop" and thinking that it is easy to fix things with a blow torch and solder---some people should never be allowed to touch anything electrical like the other guy on here currently blowing amps up with his lethal wiring and shorted Speakons.
BJtheDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BJtheDJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2022 at 1:08am
Most likely economics of scale - cheaper to buy in one size of
case and put every amp into that rather than buy 2, 3, 4 different
sizes of case.
At my independent boading school (long since closed) back in
1962 when we were snowed in for a week) we found snow melted
in a line down the side of the physics hut (yes, it was a large hut)
corresponding to the location of the one of the 2-bar electric
heaters on the wall.
When the inside boards were pulled down it was found that each
2kw heater had been wired with 5-amp twin cable - no earth, and
both had a bolt rather than a plug top fuse.
Power supply for each dorm was a single 3 pin 5-amp socket.
Damn, those were the days.
It's a difficult choice, would you rather have:
A: A vegan son.
B: An OnlyFans daughter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2022 at 6:57am
That is definitely one for the Hall Of Fame!   Clap
fatfreddiescat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatfreddiescat Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2022 at 12:31pm
Found this when I took the powercon of the end of a 13 amp cable that came with a new amplifier:
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2022 at 2:09pm
DJG DC-2 amplifier
LOL  That sure is a big case for a doorbell.
Edit...i wouldn't spend too much time on it Kevin, they are only $145 brand new!
https://www.alibaba.com/product-detail/China-nx-audio-amplifier-DC4_60589436263.html
Edited by jbl_man - 08 February 2022 at 2:14pm
M4trix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M4trix Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2022 at 12:20am
Looks like the chassis has holes for three options: 1, 2 or 3 toroidal transformers. Tongue
Ermm...cough...in other words, throw out its guts and send me the chassis ! Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2022 at 8:21am
$145 (£107) is for the massive DC4, this is just a DC2!
North Staffordshire
Esc4pe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Esc4pe Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2022 at 10:54am
DJG DC-2 amplifier
Listed specs for 1 ohm?! Shocked
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2022 at 11:04am
T-Amp S-150mk2
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2022 at 3:53pm
^ Quite a tidy little thing? 2x150w into 4, decent heatsinks,good value little amp?
