Amp Internals 2 |
Page <1 240241242243244 245> |
kedwardsleisure ![]() Old Croc ![]() Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4696 |
$145 (£107) is for the massive DC4, this is just a DC2!
North Staffordshire |
full speed ![]() Registered User ![]() ![]() Joined: 20 January 2010 Status: Offline Points: 237 |
Esc4pe ![]() Registered User ![]() ![]() Joined: 08 August 2021 Location: England Status: Offline Points: 111 |
Listed specs for 1 ohm?!
T-Amp S-150mk2
jbl_man ![]() Moderator Group ![]() Joined: 12 January 2005 Location: London. Status: Offline Points: 11024 |
^ Quite a tidy little thing? 2x150w into 4, decent heatsinks,good value little amp?
I guess it was good value until it died. Surface mount overheated and burned the pcb so now it's scrap.
d.antonis ![]() Registered User ![]() Joined: 04 January 2009 Location: greece Status: Offline Points: 44 |
Nice box and heatsinks for any power amp diy project. Class d for example.
Andylaser ![]() Registered User ![]() Joined: 16 April 2010 Location: Southampton Status: Offline Points: 262 |
If the tranny is still good, a set of aftermarket mosfet boards woud work well.
"music so loud, that if we move in next door to you; your lawn will die" - Lemmy
al_x ![]() Young Croc ![]() Joined: 12 February 2006 Status: Offline Points: 808 |
CVR D-3302 54 capacitors on each output board, 18 on the power board. ![]() |
Crown/Amcron Powerbase 2 from 1987. Basically a striped-down budget version of the Microtec/Macrotec range. Same hardware, same PCBs, even has the same ODEP board as the Microtecs. In good shape this for 35 years old. All original inside.
Earplug ![]() Old Croc ![]() Joined: 03 January 2012 Location: Europe Status: Offline Points: 6802 |
Wow - that is clean. Where has it been used? Home stereo? They are/were quite popular here as a stereo amp for those that wanted a bit more uuumph than the typical hifi amp. |
Thats good. Decent well laid out design.
